Delta Pulse
  • Originally posted by Nicolas View Post
    Hi
    Sorry No character displayed on the LCD.
    thanks
    Assuming everything is wired up correctly, it seems that you may have a software problem. Try writing a small test routine to pulse one of the digital I/O pins. Then you can see that the PIC is actually functional.
      Hi Qiaozhi
      I tested the PIC is functional pin - pin with osciloscope
      My problem is that the PIC 16F676 and PIC 18F252 gives the same thing
      no character on LCD
      The Wiring is correct
      The program works on ISIS
      I tried 2 programmer to download hex file. but still nothing
      I try again where is the problem
      and tips for a friend who managed to work their detector with both program
      • I wrote the hex into the chip with Pickit2 (i bought the programmer from a hungaryan man - like this http://www.mikroklub.hu/htm/jpg/pickit2c.jpg). This LCD is working with PIC 16f676.
        • Originally posted by szucs_g View Post
          Hi szucs
          Thank you my congratulation for the new.
          I also used the PICKIT2 MICROCHIP but not working.
          What's New for the PIC 18F252 LCD for discrimination
          Is it working? whether some tips please friend.
          cordially Nicolas
          • coil 110*110
            hi all
            I made a coil with 110 cm cable adsl I love what is the value of series resistance meter that I have because I do not own the multimeter to measure the coil.
            thank you
            best time
            P.
            • Hi pigeon
              -U coil 110 cm adsl cable 2x8=2Tu,,,,1.125uh,,,,~7ohm.
              best time
              j
              • Originally posted by jap View Post
                Hi pigeon
                best time
                j
                hi jap
                thank you very much for the answer. I did one round cable adsl
                best time
                P.
                • Hi pigeon
                  for 1TU[NOT GOOD] U coil 110 cm adsl cable 1x8=1Tu,,,,303uh=NOT GOOD,,,,~3.5ohm.
                  best time
                  j.
                    Hi pigeon
                    best time
                    j.
                    hi jap
                    again thank you. So I do two laps adsl cables with resistance of 7 ohms
                    best time
                    P.
                    • Hi, this stabilizer is very warm, is it normal ?
                      • Does anyone have the full version of diskriminator.rar
                          Hi sakis1
                          HEX file for the descrimination in TEXT
                          best time
                          j.
                          rar is locked,what is the password ?
                          • hi jap
                            is what I use the same adjustment to the coil 50 cm and 1 meter coil or each coil has its own adjustment?
                            thank you
                            best time
                            P.
                            • Hi brabra
                              u read now
                              jap
                              Hi pigeon
                              with two coils Same specifications U coil 110 cm adsl cable 2x8=2Tu,,,,1.125mh,,,,~7ohm.
                              best time
                              j
                              • Jap I don't see
