Delta Pulse
  • Originally posted by ouiarabe View Post
    excuse me my friend I did not pay attention your circuit discrimination with PIC16F676
    what is this supposed to mean?
    what discrimination are you talking about?
    • I did not use PIC16F676,however the code works fine,displays battery voltage and signal strength.
      • Originally posted by Saromines Ramiel View Post
        Hi! Nicolas did you solved the problem of your LCD discrimination? what programmer you,re using? I have the same problem,.
        Hi Saromines Ramiel
        Yes I Have resolved that... I use programmer type PICkit 2 v2.61
        But not again stable with frame 1x1m. it's ok with coil 40cm
        A remark to not: put potentiometer to determine the value of RX. So that the program is displayed on the screen.
        Best time
        NicolasClick image for larger version
        • Originally posted by maximusdesmus View Post
          hi my friend look at this video
          http://www.youtube.com/watch?v=-38M2R-3U-o
            Hi ouiarabe
            Good work my friend charchabil .......good luck and forward
            Cordially nicolas
            • May i know what value of two resistors in the RX? (you have a nice panel bro!)
              • Originally posted by Nicolas View Post
                Hi ouiarabe
                Cordially nicolas
                thank you very much my friend Nicola and thank you to our teacher in this wonderful forum
                cordially ouiarabe
                • Hello folks, i have made lcd display for delta pulse with pic 18f252, but there is a problem! I think that hex files are not good!
                  I am using files posted by JAP.
                  First when I put hex into my pickit2 programmer i got this warning as you can see on the photo.
                  Second,at first I tried to use en-lcd.hex but i got just a blank screen, so i tried with disc.hex ( turkish version) and I got this what you can see on next photos.
                  I have reviewed pcb few times in detail, and everything seems ok.
                  Does anybody have the same problem and how can I resolve it?
                  • Originally posted by strujas View Post
                    HELLO FRIEND
                    YES I HAVE THIS PROBLEM AND I HAVE RESOLVED IT
                    THE PROBLEM IS THE VALUE THE RX
                    PUT TWO POT IN PLACE THE RX
                    RX1 = 4K7 .. RX2 = 600 Ohm
                    FOR THE PROGRAMMER IS GOOD NOT WORRIED IS GOOD
                    THE HEX FILE BY FRIED JAP AND TURKUSH IS GOOD ALSO
                    -----Note-----What you see in yellow on the program does not matter
                    You can ignore this message ... the file
                    s is downloaded as no Error message Error.
                    THIS IS MY RESULT
                    http://www.youtube.com/watch?v=2cHK4WVcwDg
                    http://www.youtube.com/watch?v=dxWcxgKPyHY
                    http://www.youtube.com/watch?v=eTBF1-tCQT8
                    I WISH YOU GOOD TIME.
                    NICOLAS
                    • Nicola
                      I do not understand that you mean circuit resistance, when you say "RX"?.
                      Is the damping resistance? any component or module of discrimination?.
                      thanks
                      Jose
                      • Originally posted by Jose View Post
                        Nicola
                        thanks
                        Jose
                        Hi Jose
                        But we speak about LCD and module descrimination my friend
                        • Thanks for responding Nicolas.
                          This module is a demo, how many times you can use the discriminator module?
                          • Thank you Nicolas, but I don't have problem with contrast. Today after dozen times of turning on and off my lcd finally gave signs of life.
                            Only turkish version of hex works and not always, often i got the same hieroglyphic signs as on photo above and sometimes is normal.
                            I don't know what is the reason for that?
                            Bad microprocessor maybe, or?
                              200 times, after that you must reprogram the chip
                                Hi Strujas
                                Good luck
