Delta Pulse
  • Originally posted by mohandes View Post
    hi kt315 and anybody
    any body work by 110*110 cm in wild land or soil or mountains .
    i want understand have good stability and good work in real ????
    i just test in air.
    you have to ask bulgarians. I have not such conds around. mine wild land is neutral anywhere. I was in Bulgaria,
    do not know as for hunting, but the ground is really hard anywhere.
      ahhhhhhhhhhh
      in my country have not graphite spray. so i should use Al foil .
      regards.
      much russians use 'copper-graphite collectors' using for trolley-buses. on terminal end stays you can find them used huge much, trolley drivers throw them away like a garbage. then mill them on any abrasive and you get the copper-graphite powder. russians do not buy the special conduct spray.
      • Comment
        • Comment
          • Comment
            • Comment
              • Comment
                • many thanks KT315.
                  i finish my new DP2 analog pcb and know just want finish discrimination pcb.
                  I have Diesel Generator , it have many Coal like this :
                  so i Shave Coal and put like you.just i should Composition any Materials like water or no ?
                  best wishes.
                  i put here lot picture and data about my Experience.
                  • I think you need to mix it with varnish or epoxy resin I used the inside of batteries and graphite pencils for drawing they are square with no wood it makes good shielding.
                    • varnish ll be good, you have to find needed varnish. maybe bitumen or on bitumen base.
                      do NOT USE polyvinyl chloride resin -!!! PVC KILL A CONDUCTIVITY!
                      • Comment
                        • hi dear Kt315
                          do you know this schematic for DP?it is work or no
                          New folder.zip
                          edit:
                          i wrong it is not DP.
                          • hi all
                            i finish another dp2 and use stth12r06d diode.work but not test yet.
                            but in lcd i have not character ???'
                            so i try tomorrow .
                            • Originally posted by jap View Post
                              Hi Nicolas
                              File HEX for the descrimination of PIC 18F252 new version.
                              best time
                              j.
                              hi
                              this version is ok?
                              i have problem with this program ?
                                hi
                                this version is ok?
                                when i want program have massage : have some error but can program , when put the PCB dont LCD dont have character .
                                excuse for my English.
