Delta Pulse
  • Originally posted by Saromines Ramiel View Post
    Hi Mohandes, i have same problem with you on DP2+ last year I make two circuits with this and get the same problem,.the trouble is the LCD I use when I turn on the circuit I get scramble letter on TOP of lcd screen.,some times like a full contrast but is not.,.I only solved this by making a quick short of +5v out of LM7805 to GNd...maybe the reason for this is the write delay of a hex and the delay of the LCD.[ATTACH]32272[/ATTACH][ATTACH]32273[/ATTACH]
    hi
    see new PCB of this.my PCB is correct and have not problem.you should set battery signal and battery voltage but Zero buttom and dont put it on pannel.just set it by multi turn .your picture show correct character on this but check it when connect to analog board.
    in net have video for learning to set signal and battery on YouTube.
    first when analog delta work then connect correctly point the LCD board.(P2,P3,...)
    big problem is file is Demo not complete , i want buy it but not now.
    my internet connection now have problem. ahhhhhhhhhhh
    • Originally posted by mohandes View Post
      hi
      Like mine still a demo but it works perfectly.,. I'm not satisfied about the discrimination in field,.the signal of aluminum tab and foil is look the same..on a coin also I observe the performance of my DP with discri LCD is a liitle bet poor in depth compare in without LCD..
      https://www.youtube.com/watch?v=6Tr1XvQi2xA
        hi
        i send PM to turkey man to buy it and ask about your problem.i will put here him answer.
          hi
          Ok thanks Mohan..
          • discriminator.rar
            for Paku. and another friend.
              [ATTACH]32290[/ATTACH]
              Thanksfull For Share Bro
                Ok thanks Mohan..
                hi
                the answer:
                hi,
                I think that there is some problem on your circuit. Also, discrimination must be good. But this bad working is not about demo. This is about your circuit. We are using paypal for money transfer but if you want bank transfer, we can use.
                  hi
                  the answer:
                  hi,
                  Nothing wrong with the circuit may be adjustments I suspected the quality of parts I used. some example in LCD circuit that need precise adjustment is here..
ID:	342588Click image for larger version
ID:	342589Click image for larger version
                  • Can you tell me the cost plus shipping of full version hex and Micro Con. here in Philippines?
                      see it for adjust
                      https://www.youtube.com/watch?v=RGocN4qcjBQ
                      and help more:
                      http://www.teknolojiekibi.com/yeni/i...p?topic=3312.0
                      http://www.thunting.com/smf/metal_de...-t28731.0.html
                        hi.so sorry i forgot to answer this.say me for one 21euro by shipping.
                        • Hi everyone! Is there a one sided pcb for delta pulse? If yes, can i ask a copy of it?
                          • yes . in turkey site and i think is free(i make it and correct). i put for you next time. regards
                              Thank you mohandes.. i smell that i can made a delta pulse sooner
                                hi
                                soncorr.rar
