new bom file for beginners
Delta Pulse
i told about R40 value much times but the people are very lazy to read and search the forum.
they ask me again and again same questions like maniacs from the horror american movie.
R40 IS SPEED OF ASAT*** RESET, or, for beginners, speed of sound nulling on reset knob pressing.
so you may set 1k... 5,6k... 10k...12k etc - you will feel ONLY what I SAY YOU ABOVE. ALL CORRECT.
is it clear there???? people... raise up your mind from the ground.
pathetic.
*** - advanced self auto tuning.
Hi KT315
Don’t get mad OK ? I am just trying to help you, and I can only write this in English, and is given in good faith.
I have been trying to work out why some people have been having trouble making your delta pulse and why they ask questions about R39 and R40.
I have been reading through several threads about your DP.
The problem seems to be there is different information spread across several threads that do not match,
the latest schematic see post #3251, and the latest silk screen on your black PCB and your latest bill of material (bom) don’t match.
You may have published the latest component information somewhere buts its very hard to find it and combine all the information together.
For some reason only known to you, since you published your latest schematic and pictures of your PCB, you have changed the values in the BOM of R39 and R40, and has caused some confusion
This problem can be fixed very easy, so people can make your DP and get it working.
First remove all pictures of your latest PCB from your album etc,
then scratch off the resistor values of R39 and R40 from the silk screen of your PCB and take new photos ,
this will make it less confusing.
Next update the schematic with new values of R39 and R40.
The updated BOM, schematic and new pictures of PCB with values of R39 and R40 scratched off need to be published together on several threads I can list them if you want.
cheers
6666
no reason to scratch off the resistor value just cause -----
--- values of XR71 are working
--- values of DP are working
--- my values are working.
i suggest you to begin to learn the f-g electronics... yes, the electronics. if you are newbie you must begin to read the useful books
not asking me why values same or not same. you are like blind squerell in the midnight hoping values will
change something, depth or what you imagine yourself... but not... no difference.
cheers
write more good story. any mention of DP will be greatly appreciated just you do my day.
cheers
May I suggest that you produce a Delta Pulse Build Document similar to those for the MiniPulse Plus and Geotech Baracuda designs. I can send you the Word document to use as a template.
It would make your life a lot easier.
I'm sure we could help you to correct the English if you have a problem.
hi George
that will be only good but my english is not so perfect to make it.
i began write some article for russian magazine but it is still not ended. also i have html from one russian Koliaj name
who was first done DP.
if who will agree to translate in english i will send him both texts.
i did pic you could see the Koliaj's text
http://storage7.static.itmages.ru/i/...539ceb8677.jpg
thank you for support
