Delta Pulse
  • this thread 147 pages and 3600 posts. again to begin from start?
    i see diagram in 45 post, for example.
    all my videos with all signals were in youtube. but it deleted my channel with resume i'm 'the spammer'.
    • I read all 147 pages but only thing i saw was your anger with other members not right advice
      Also i saw 2 or 3 pictures from scope diagram on these 147 pages that were related to test points tr2, tr3 , tr4 , tr5
      • i do not keep the videos because all were in youtube.
          point T3
            point T4
              T5
                T1
                T1 WHEN metal target in contact with coil
                i have no sound in speaker
                • how check the sound
                  https://www.youtube.com/watch?v=ODtvLeWdre0
                  • right reaction
                    https://www.youtube.com/watch?v=geX1BcgZrAY
                      i redesigned the pcb from anatolij files
                      If anyone finds an error please tell
                      • tell me about small coil number of turns an wire size?? is the resistance and inductance same as 1*1 meter coil?
                        • this is test coil 350uH. with ferrite rod. 1x1m coil is 550uH, 16 turn.
                          resistance... i do not interested in measuring resistance... 3 or 1 ohm - is difference?? in what???
                          • How much is voltage of 4700 uf capacitors?
                            • ahaha! i did think you are my customer from Iran, but i see you are just thoublemaker.
                              voltage of a capacitor. must be ABOVE of a voltage in a place it is used. for example, power supply is 12 V. that is mean you must take a cap on 16V. ABOVE!!!
                              NOT 6.3! NOT 6! NOT 10! those will be BURNT!
                              i see your knowledge in electronics is sure zero ((( you just try to get knowledge 'on-the-run-for-horse'. that factor sure significantly reduces your chances
                              on success. very lamentably.
                              • Capacitor Explosion Experiment https://www.youtube.com/watch?v=MLpvvFg06kc
                                https://www.youtube.com/watch?v=ZUiOBYj8Kps
