Delta Pulse
    Hi All.
    Delta Pulse don't work with 6V. It has in series with power suply two diodes so the voltage will be 6-1.2=4.8V,very low voltage. If you modify the circuit.... who knows...maybe to work. When the voltage is lower than 9V the detector is unstable and has very low sensitivity.
    Bye
    Hi Geo,
    yes there are the 2diodes for op amp supply...like in xr-71 and it cannot work at 6 volts with original op amps I think...but using e.g. tlc2262 it could cause these devices require less supply voltage instead of tl0x2 types.
    Also other things could do the job I think, like:
    TLC2252
    TS272
    TS27M2
    TS27L2
    MC33178
    LS204
    Anyway I've never tested...just my hypotesys. For other components it's not a problem having less supply voltage (cmos, 555 etc).
    Instability is due to nearing of saturating voltages with useful signal...then when signal increase we can easy have saturation on op amps.
    With rail-to-rail (e.g. 2262) problem is well reduced and you haven't any istability. Also consumption is much lower...than with TL0x2 series.
    Best regards,
    Max
    • hi
      I have adaptor with these features
      input: 220V 50Hz
      power: 9W
      current :500mA
      output:1.5 V , 3V , 4.5V , 6V , 7.5V , 9V , 12V
      can I use it to test delta pulse.if it is working or not?
      is 500mA changing while changing voltage?
      okantex
      • btw since I do not know tecnical terms of electronic .I want to write the things on my battery
        6V-4.5Ah/20HR
        constant voltage charge
        voltage regulation
        cycle use........................:7.35-7.5V
        stanby use.......................:6.75-6.85V
        max. charg,ing current...........: 1.35A
        does this cysle use hhave any meaning for more than 6V .
        can we think 7.5 -1.2 =6.2 bigger than 5V and enough for delta ?
        • 4148
          The two PS diodes for what reason have used? They cause that gate driver voltage (S-G) be between 1.5 to +VB...
          Is it better that we short them?
          • Originally posted by okantex View Post
            6V-4.5Ah/20HR
            voltage regulation
            Hi okantex,
            current is not regulated in your supply so it depends on voltage applied and load (ohm's law).
            Battery is a gel-lead-acid type , that I know well...and could be used on this kind of circuits with success...due also to low internal resistance...but is heavy for my taste.
            Anyway...voltage accross battery vary from full charge state to full discharge...but you can use it. Just you need some adjusting on threshold when discharge causes your detector go out of tune...say every ten minutes or so...
            I've used many 12V 4aH and 12V 1.3ah on my pulse induction devices...works good but the more the current capacity the more the weight.
            I suggest to buy a battery that could cover 6-8 hours of detecting maximum...or buy more than one and the changing them when discharged on the field...6V 4.5 AH could be heavy to transport e.g. hip-mounted. Anyway...It's your choice.
            Just put on the supply lines a fuse of 500mA FAST to avoid problems if reversing wires...to save electronics ! Better would be a limited current power supply for testing...but some are expensive lab devices...
            Best regards,
            Max
            • Originally posted by 1843 View Post
              what's important is gate Vgs fall time...not a real problem to have some volts under Vgson...if this is the question.
              Other important issue is that fet is fully turned on at +VB and this is the case here at 12V.
              For 6v operations one could use a lower Vgson device with same transcapacitance.
              Best regards,
              Max
              • Hi Max
                I could not understand what you mean.
                do not you tune your detector at every 2 minutes.
                do you mean something else?
                my battery is something like 1 kg .no more.I am sure your 12v is heavier than mine.
                I am not sure if it can drive ICs .after GEO 's words.
                I looked datasheets of IC .they say supply voltage is +-15 or +-18
                but we use them at 12V .this is also a big quessstion in my mind.
                A friend say .he used 7v .his coil was 45 turn ,60cm diametre ,0.8 wire.
                I tried to calculate inductance it was 3000microhenry?????
                does not it be something like300mh?
                what is supply lines ? as ı said I am not electronition.just hobbiest.
                can I charge my buttery with my adaptor .I gave it's properties at previous mail.
                thanks
                  6V-4.5Ah/20HR
                  voltage regulation
                  Hi okantex,
                  about your battery...what simbols means (BATTERY TRAINING):
                  6V-4.5Ah/20HR
                  voltage regulation
                  means that battery requires constant voltage charging, in cycle use voltage from 7.35 to
                  7.5 volts can be used...that means that if the battery is cyclically charged discharged
                  frequently you can use that voltage e.g. 7.35V to get it fully charged.
                  In standby mode...like in emergency lamps...where the battery stay charged for long time
                  6.75-6.85 voltage is used to keep the battery charged and avoid self-discharging due to
                  internal leaks- you are not interested in standby charging (so called...trikle-charging).
                  You need a full charged battery then to discharge due to using your metal detector and then
                  recharge it...it's CYCLE USE.
                  So you need to charge from 7.35 to 7.5 volts constant Voltage.
                  max. charg,ing current...........: 1.35A means you can't go over this value without damaging
                  your battery...avoid more current also because hydrogen is produced internally and battery
                  could explode at higher charging current - very dangerous, don't do that.
                  You need to provide enough current for enough time
                  example: at 1.35A you charge the battery in about 3.333 hours (4.5AH/1.35A).
                  I suggest using 1/10 of capacity current for 10 hours: 450mA (at constant 7.5volts !) and you
                  need some constant current charger to do that (you can find schematics on google: "charger lead acid lm317").
                  Or also better 300mA for 15hours. The longer the time...the longer lifetime of device and less
                  troubles...and also better charge at constant voltage cause hydrogen is adsorbed or expelled safely from the
                  battery (on some types there is an automatic hidden valve that do it).
                  20HR means that battery discharge is related to current delivery...
                  example: 4.5AH/20H --> 225mA is the maximum current you can draw from it without losing some battery
                  capacity...actually you can draw more with a 15-20% reduction of total capacity due to losses.
                  If current is too hi...you damage the battery and if shorted it could , again, explode.
                  You can also try to charge the battery using a normal unregulated supply...but I think it's not a good idea...
                  cause you need some limitation to charge it safely.
                  "does this cysle use hhave any meaning for more than 6V ."
                  When you have a fully charged battery you get a little mre than 6Volts...it's normal to have cause the cells
                  gives more voltage : a lead-acid cell is of 2Volts nominal...but you can get from 2.05 to 2.125 when fully
                  charged then you could have something like 2.125*3 = 6.375 volts at full charge...simply doesn't matter !
                  When a single cell go under 1.8volts it's fully discharged...so if you get
                  1.8*3 = 5.4 volts...you battery is game over and need recharging.
                  "can we think 7.5 -1.2 =6.2 bigger than 5V and enough for delta ?"
                  Your 6V battery cannot gives 7.5 volts even if fully charged. If so...battery is damaged and you need new one.
                  you have 6-1.2 = 4.8 volts: that 1.2volts is enough for many devices to read signals and stay away from
                  saturation, cmos and 555 would work fine too.
                  Real problems could be:
                  - Vgson for mosfet device (usually 4volts are enough to fully turn on but not always)
                  - lower audio volume (cause you have less vcc)
                  but most important is:
                  - OP AMPS polarization...supply : some devices don't like lower voltages...you need low
                  supply op amps like tlc2262 or , easy to find, e.g. lm358 to solve that problem. Usually a
                  single supply op amp could work at lower supply than dual supply devices... e.g. LM358 can
                  do it, better e.g. NE5532 (lower noise)...but better than everything is having rail-to-rail op amps there
                  cause also tl062 could work...but can be unstable in these conditions where saturation voltage
                  is too near useful signal level.
                  So, you can use tlc2252,tlc2262, ts27m2, ts27l2, mc33078, mc33178, ls204 instead of originals.
                  Best regards,
                  Max
                    Hi Max
                    thanks
                    Hi okantex,
                    "I could not understand what you mean.
                    Yes. Not 2 minutes but 10-15-20minutes YES. Because (this is a fact) both xr-71 and deltapulse haven't any internal voltage regulator...so VCC that is the battery level vary with discharge of it.
                    Actually I have on mine...voltage regulators but this is another story...in posted schematics there isn't so you need to retune sooner or later. The bigger your capacity of battery, the slower the discharge at a fixed current the longer it takes to need threshold adjust.
                    Actually I don't need to adjust periodically now...but I've done before using original schematic and 1.3 AH 12 V battery.
                    "my battery is something like 1 kg .no more.I am sure your 12v is heavier than mine.
                    but we use them at 12V .this is also a big quessstion in my mind."
                    You are lucky...some of my batteries are heavier but also 1Kg is heavy for me...anyway...I'm lazy on that point!
                    Well...+-15 or +-18 are absolute maximum ratings...means that over that you burn your devices...
                    Actually you can use them on lower voltages e.g. +-5 or also +-3 or less.
                    For instance mc33178 could work very happy at+-2.5 volts and there are even lower supply devices (some works on single 3 volts and even less!).
                    "A friend say .he used 7v .his coil was 45 turn ,60cm diametre ,0.8 wire.
                    Could be. I told you that only some components could require attention to work at 6V or be substituted. Must be 300uH.
                    can I charge my buttery with my adaptor .I gave it's properties at previous mail."
                    Well yes...you can but you risk to damage it in charging. Supply lines = the positive or negative wire from your battery to the circuit - put the fuse there on one of these wires.
                    Hope this helps.
                    Best regards,
                    Max
                    • Hi
                      I used 12v 45Ah car battery for test.
                      also used 1100miccrohenry D=5cm small coil,ırf840 ,vu meter, and 0.5W 8ohm speaker.
                      rest are same with kt315 's list.
                      first I hear sound like door creak .it continues something like 10 seconds .then stops .and when I put metal (it was iron) infront of coil ,I got no sound.
                      when I repeat process.I mean close and open detector .same thing happens again.
                      where is the problem
                      I connected 555's 2. & 6. pins.
                      And on vu meter there is + and - inputs.where must I connect them.which one is jp1 (+ or -)
                      • hı... I made a delta pulse but ı have a problem. my delta pulse sound always beeeep ı dont know where is my mistake? please help me. how can ı work it:?
                        • coils
                          I need to make two coils for Delta Pulse, 2*2 M & 50cm.
                          any help please for the wire gauge and number of turns.
                          thank you,
                          • Originally posted by mosha View Post
                            thank you,
                            2x2m: 13turns 20AWG
                            50cm: 33turns 22-24AWG
                            For better coils you should ask ivconic!
                            Good luck
                            • thank you very much
                              • For 2x2m coil it is better to try 9 turns with wire 1.5...2.5mm
