Delta Pulse
  • Hi Batman. I attach you the manual for Bandito-Impulse. It is the same detector with Delta Pulse.
    • Singel layer pcb for delta pulse
      • Geo 1. I never saw a one side pcb for DeltaPulse.
        nelson You are right Geo. My pcb is a one side with lots of jumpers on it to configure the original board, but it must be some errors on connectios
        Hi
        Singel layer PCB for sniffer xr71 and delta pulse.
        • hello aft
          where is the paths?
          • Hi aft_72005.
            Nice work
            Did you tested this pcb?
            Mine is a one side pcb, but with lots of jumpers.
            Can you share pcb files to check it?
            What pcb software you use to get the one side pcb?
            I have sprint layout 5.0
            Other softwares like eagle, orcad, proteus are here too, but i m just trying to learn how to use it.
            Waiting for your response.
            Best regards
            Nelson
            Hi
            • elbombacı design of delta pulse single sided
              • http://www.teknolojiekibi.com/yeni/i...ic=4.msg6#msg6
                elbombacı designed
                http://www.savefile.com/files/1018088
                • Hi Nelson
                  No, I don’t test yet .because it completed later.
                  Drew it with sprint layout 4 .can you send me
                  Your drawing?
                  I am seem you, have eagle, orcad,proteus also
                  Protel .I am working with protel and sp4 and sp5.
                  Me email: aft.72005@gmail.com
                  Regards.
                  • Hi erolunall
                    Had differences between my drawing and elbombaci.
                    • Hi my friend.
                      No i don´t have the file. I just did the original doble side pcb with lots of jumpers.
                      Now i m tring to draw on sprint layout 5, a pcb for Anker 60.
                      Do you have Delta Pulse one side on sprint layout file to share it?
                      Nelson
                      Hi Nelson
                      Your drawing?
                      Regards.
                      • Hi Nelson
                        Please let me check my drawing.
                        If it is ok, then send for you.
                        Regards .
                        • HELP ME PLEASE
                          HI GEO I AM FROM IRAN.
                          I NEED Component List DELTA PULSE.
                          I DONT KNOW NUMBER:
                          RESISTORS = ? WATT AND HOW %?
                          CAPACITORS :
                          C7 220UF = ??V
                          c8 10uf = ??V
                          c12 100uf = ??v
                          c21 10 uf = ??v
                          c27 220uf =??v
                          and c29 100 uf = ?v
                          thanks alot for help.
                          hamzeh2536@yahoo.com
                          • I AM SORRY FRO USE YOUR NAME
                            HI all.
                            i am sorry fro use your name UNREGISTERED!!!!!!!!!!!
                            I AM FROM IRAN!!!!!!!!!???????
                            I DONT KNOW NUMBERS:
                            RESISTORS = ??? WATT AND HOW %???
                            CAPACITORS :
                            C7 220UF = ??V
                            c8 10uf = ??V
                            c12 100uf = ??v
                            c21 10 uf = ??v
                            c27 220uf =??v
                            and c29 100 uf = ?v
                            send my mail
                              I DONT KNOW NUMBER:
                              RESISTORS = ? WATT AND HOW %? 1/4watt........ 1...5%
                              CAPACITORS :
                              C7 220UF = ??V All capacitors at 16V minimum
                              c8 10uf = ??V
                              c12 100uf = ??v
                              c21 10 uf = ??v
                              c27 220uf =??v
                              and c29 100 uf = ?v
                              Hi.
                              Good luck
                              • HELP ME PLEASE
                                I DONT KNOW NUMBER:
                                CAPACITORS :
                                C7 220UF = ??V
                                c8 10uf = ??V
                                c12 100uf = ??v
                                c21 10 uf = ??v
                                c27 220uf =??v
                                and c29 100 uf = ?v
                                Hi
                                Seem as you are beginner , and for you better begin with simple pulse
                                Induction .
                                Regards.
