Delta Pulse
  • DP not reflex!
    Dear Geo
    my DP was finished yesterday(I used Kt315 PCB and elements)TR1 is IRF840,but i have some problem
    and question.pls guide me what must i do?(below result was without connect coil to DP)
    1- i know PR1 pot is for tune the frequence but in which check points exacltly i can see correct frequence
    (100Hz) by Osiloscope or Fr meter?
    2- When i power switch ON,the power LED turn on for a very shot time and turn off again and it will not be On but Tune switch
    work and microAmp move up,what is the problem?
    3- i had a mistake!!!the battery was short contact and circuit was connect,is it possible circuit damage ?
    is it possible send me ur DP schematic,PCB and element detail ?
    sorry for bad english
    thank u very much and goodluck my friend
    • sorry for a mistake!
      Dear Geo
      2- When i power switch ON,the power LED turn on for a very shot time and turn off again and it will not be OFFFF but Tune switch
      • Originally posted by batman1972 View Post
        Dear Geo
        Hi, To read the frequency you must connect the probe at the tr2.
        I don't think that the circuit has damaged from battery short.
        If you will read this thread from page 1 you will find every DP schematic. I use the schematic that writes Micron Electronics........Delta Pulse.
        • Hello All
          I attached single sided delta pulse in sprint layout 5 format drawed By Hakan Durmaz from elbombacı design pcb .he has www.durmazonline.com about detectors Please write if find any errors
          http://www.uploadpaylas.com/v/1450483/son.lay.html
          • hello
            attached zipped lay of dp single sided
              Dear Geo
              Hi Oscar. Connect a coil and look if the detector response at any metal. If yes change the led or the series with led resistor.
              • DP Help
                Dear Geo
                My DP coil has alminium foil sheild(i use Cat.5 network cable for it).
                1-where must be coil sheild connect on DP ?
                2-where must be Coaxial cable shield connect?
                thanks and goodluck my friend
                  Dear Geo
                  Hi.
                  Coil shield must be connect to +E (+12V). I have tried it at -E with the same results.
                  • one side pcb for DeltaPulse
                    Hi
                    dear geo
                    is it really Correct one side pcb for DeltaPulse?
                    how many power? does has it value for build?
                    thanks for reply.
                    good luck.
                    • Hi. I did not construct it. But as i saw at a Turkey forum this pcb works well.
                      Download the demo version of sprint layout 5 and open the file son.lay who Erolunall has post here.
                      • Dear 786
                        I constructed it and working good.I will put picture of DP here soon.
                        Elbombacı made LCD for DP.
                        You can find below link about single sided dp but YOu have to ask elbombacı about LCDç
                        http://www.teknolojiekibi.com/yeni/index.php?topic=4.0
                        Best Wishes
                        Erol Ünal
                        • 786, i m also constructing the one side pcb for delta pulse. So please tell us your expirencies.
                          Nelson
                          Originally posted by erolunall View Post
                          Dear 786
                          Best Wishes
                          Erol Ünal
                          • Hi Nelson
                            There is no performances changing.But very easy for building.
                            I attached parts replecement.
                            I wonder can we attach Digital ampermeter to delta pule below link?
                            http://elfly.pl/multimetr/multimetr_en_DIP.htm
                            • Thanks for this information.
                              Yes, when i get it working, i ll try to place a meter too.
                              Best regards
                              Nelson
                              Hi Nelson
                              • Original Delta Pulse has an analog instrument (microameter). But for me ....DP don't need it. The sound is analog to meter indication so why to use it ?????
                                My Opinion
