Delta Pulse
  • Very nice! Congratulation.
    This is my dp:
    http://www.teknolojiekibi.com/yeni/i...hp?topic=325.0
    http://www.teknolojiekibi.com/yeni/i...hp?topic=471.0
    This is my coil of dp:
    http://www.teknolojiekibi.com/yeni/i...hp?topic=171.0
    This is my dp with bar graph:
    http://www.youtube.com/watch?v=6l-UOFggl-4
    • Hi ,
      Your PD with the LCD showing the decay curve is really great.Nice work with the coil and other PD too.
      Good luck!
      regards,
      Fred.
      • Great! Thanks for to show us your fine job!
        Esteban
        • Channel 1, 20 Volts/d ???
          Hi Nelson
          At the final communicate with you, I think you be able
          Running you delta pulse. Because I don’t have another mail
          From you.
          Any way, as I said you latter, one of the important measurement
          Industrial is oscilloscope. It is better if you borrow oscilloscope
          From a friend in your local area.
          See attached picture, channel two show pulse on gate irf740.
          (upper waveform)
          Channel one show output of amplifier, pin 1 of TL062.
          (lower waveform )
          The Channer one is 20.0 V... I believe that the PIN 1 of TL062 can't go to more than 5-6 Volts ????
          Some body have another wave forms, my DP have problem now, I need. For example, the PIN 6 LF357... ??? All TRs ???
          diminute
          • Hi
            diminute ,Tek oscilloscope had probe multiplayer button with 1x, 10x, 100x, 1000x ranges
            Please see again picture probe multiplayer button set on 10 x, thus your real voltage is
            20/ 10=2volt per section, amplifier out put level are 8.8 vpp.
            • Originally posted by aft_72005 View Post
              Hi
              OH!!! thanks.
              Do you have anothers wave forms, I am making my DP but I have some problems... the detection is poor. When a push autotuning button i have a 1 Hz tone, but after 1 or 2 seg the detector become out tuning... the tone is increasing without control until reach 1Khz or more, like a object be near the coil.
              I can't understand how the DP work, I don't know how work the TL062s, how work the autotuning. Can I eliminated autotuning and use only the threshold knob ???
              What's the function of U6B (TL062) joined with LF357.
              I would appreciate it if you would explain me some these things, and give me another wave forms from others analog functions of DP.
              Thanks !
              Diminute
              • Hi diminute
                I upload more pictures in future, u6b: it is integrator,
                Part of feedback section , for Stability of u4 amplifier.
                Auto tuning: u7a, compare receiver signal on pin 2 with signal from
                Out put of Integrator u7b, the result is error signal on pin 1 u7a, applay again
                Via r33 to U7bin put.
                • GOOD !!!
                  Very important to me your explication.
                  May be you can say me that's the function of T3,T2 ??? Another question is the function of VD14 (8v2) & T8 ???
                  U5 is a simple amplifier ???
                  One MILLON of THANKs to you...
                  diminute
                  • Hi diminute
                    U5: opamp U5a are Receiver amplifier, u5b Receiver inverter and limiter .this ic ouput
                    Level limited approximately on 1.2vp
                    T3 and T2 are synchronizer ,this section out put (T2collector)
                    Produced pulse for snick timing circuit with receiver section.
                    Regards.
                    • Ok, my DP is walking...
                      Now I am working with the information that you give to me.
                      So many thanks for you and another members of this great forum. I am very Happy with all you.
                      My DP is improving, newly thanks to you.
                      I have a new question, is refer to the output of my LF 357 (i don't have one, i put TL071). In the attacment I put the wave form of the output, I have aprox 20 uSeg with no signal (negative planar), after that the signal is increasing, but have two noises... is the TR4 and TR5 signal that are afecting the signal softness, is correct that ??? or I need to consider like noise ??? Somebody know that is happening.????
                      Thanks.
                      diminute
                      • Help
                        Nobody answer to me ????
                        thanks,
                        diminute
                        • Originally posted by diminute View Post
                          thanks,
                          diminute
                          The waveform is not good
                          Look.....
                          • Hi diminute
                            Examine this work and say me , when you change signal and sens pot. , are you seeing
                            Movement of two noises on curve?
                            • Oh, yes
                              The noises is the two signal, when i move the two pot the noises moves with. May be there are some interference.
                              When I put the second channel of my osc, I can see that coincide the noise in the output LF357 and two signal.
                              Thanks,
                              diminute
                              • As you said , when turn on second channel, two noise appear on output LF357 waveform
                                Remote repairing is difficult, what you say, in my opinion, maybe this
                                Interference occurred in your oscilloscope, recheck and tune osc. Coupling setting
                                Section.
                                Regards.
