Delta Pulse
  • Originally posted by SIBI View Post
    Hi guys!
    Indoor detect DP very well, but outdoor in clean place without metal object is detection poor I have 1*1M coil, wire 0.7 dia and 16 turns. I played with dumper rezistor, but with no big efect. Sorry for my english, i´m Czech
    IN THE ROOM YOU CAN TEST DELTA PULSE ONLY WITH A SMALL COIL! even do not try to test DP with huge coil in the room!
    18-24 cm diameter coil will be very OK for the test.
    • Originally posted by apocalypto View Post
      I finish the making of delta pulse, I tested it..................nothing [angry]
      - Battery : 12V 2.3 AH
      - Serach coil : ø25 cm, 30 turns of 0.5 enemable CU
      - Volume capacitor (100 ohm) not assembly
      Results :
      - Nothing.
      - IRF 740 Heat in 5 min working.
      - very Low noise from Coil search
      begin testing on small PULSE WIDTH value. tune P3 on 50 ms of PULSE WIDTH.
      • KT315: I known, but why is detection in room better than in forest? I played with all pots, but with no result. All pots was in max without false signals, but i detect my army shovel only at aprox 40cm
        • Please help me kt315
          My delta pulse not work :
          - LED VD 17 (work / red color)
          - LED VD 16 (not work)
          - Nothing beep or sound
          - IRF740 Heat
          - I measured the voltage +E and -E between 1 and 8, 1 and 4 of D6A (+5.xx and-5.xx volts)
          I don't know what i do and i hav't oscillo
          Please help me
          • Please kt315 what i must do?
              This the pictures of my delta pulse
              Turkish PCB layout? I know nothing about it. in my opinion you must check the layout and have a list of mistakes on PCB to fix these up, to foresee all. you did not measured resistors and capacitors, do not check all transistors before soldering into PCB. I am not a magician to say outright where you have the problem.
              • I cheked all ressitor, can you give me some point test (voltage between point.....) to localised the problem?
                • another information R5 = 2.2 k 1 W
                    Hello apocalipto
                    The tests I performed with coils of 25 cm. in diameter, worked well with damping resistance of 500 ohms or less, on an experimental test, never got good results with 2.2 K, always 680 ohms or less and medium-sized rolls of 40 x 40 cm.
                    Sincerely
                      how? what way you see? if PCB is good quality made and without mistakes, you soldered all details checked you get absoliutely stable working device RIGHT OFF!
                      • KT315
                        I have finaly a sound from my delta pulse after i monted the volume potentiometer, but its a continued sound (~15s) repeated each 30 seconds i whould like to know how i reguletd the potentiometers, i hav'nt oscillo.
                        please KT315 tel me true or false :
                        - damping resistor D5=500 ohm for smaller coil
                        - damping resistor D5=2.2 k for big coil (like 1m x 1m)
                        cordialy
                        • Hi kt315, i tried everything you mention, but still no sound.
                          I was thinking that will be much bether to finish my fifth delta pulse and then with a working unit, i will take muasurements to compare with tha bad one.
                          Thanks a lot for your help that i really appreciate.
                          Nelson
                          Nelson, with T9 soldered you must get a sound in any THRESH tuning position, I think. try reconnect that I did draw here and you must hear a sound. decrease R44 value to 20-33 Ohms. desolder R45 too. also check R46 - it must be 2-2,2 Ohms.
                          • Please help me
                            A continued sound from My delta pulse please help me
                              Hello Apocalypto
                              Could it be that this maladaptive coil and R5, automatic mode Pulse Delta, tries to compensate.
                              Try to R5 300 to 500 ohms, or install resistors in parallel to decrease the value, not anything bad will happen to the team.
                              Pulse width or power, from 30 to 40% of maximum.
                              Delay, the minimum or low.
                              Other controls 100%, note that the gain control is usually invested in some PCB
                              Apologies do not speak English
                              Sincerely: Jose
