Originally posted by steaua581
Delta Pulse
Originally posted by steaua581 View PostHello Mike Bg and forum,
Thanx for your help ..You think instead 80uS arround 100uS on TR 2 will be allright?
Marius
you have to change somes composants az tell Eugene...
-R47,R49=2k
-R5=2k2 1w
-R6=1k
-C7=220uf (not 1000 uf)
-C1= 15nf (not 22 nf)
then i think you get best result...............regards raff33Attached Files
Hello kt315 and other friends
I can not find the diode stth1210
Please help me replace this piece
Can I work take 1n4001 or 1n4148 ???
Please help me
Please help me
You can use for example BYV26C or 1N4937
(BYV26C - 600V 1A Fast Recovery)
(1N4937 - 600V 1A Fast Recovery Diode) -
(MUR480EG - 4A 800V Ultra-Fast Recovery Diode)
(FR605 600V 6A Fast Recovery Diode) - these diodes are available from www.futurlec.com, as well as many other distributors.
Actually, if you go to www.futurlec.com and perform a search using "fast recovery", you will find heaps of suitable diodes, depending on your desired current and peak voltage.
Nicolae
TANK YOU KT315
FOR 40CM COIL >>>>>22 TURN NUMBER WIRE 2MM (14SWG)OK?????
DEAR KT315
WHAT BEST WIRE AND TURN FOR LOOP 1*1 FOR???
PLEASE HELP ME
I made a delta pulse
but my Delta pulse allergic to camping is a little gold and copper
Please help me to obtain high sensitivity to copper and gold
Good luck
jack
DEAR KT315
PLEASE HELP ME
Good luck
jack
I am going to build the Delta Pulse Metal Detector. Only, I am indecisive about which version of the PCB I will use. Both versions, the single-sided and double-sided PCB designs seem to work OK judging by what I have read.
However, although more compact in design, is the double-sided PCB version worth the extra hassle. And I am referring to making a through-hole specimen in which the top and bottom layer are though-hole galvanically interconnected. Well, I am going to have to make this decision on my own, for I have not yet read any posts about layout disadvantages between both PCB versions. I would have to make extra expenses in manufacturing the double-sided version. However, materials obtained (extra expenses) to make a double-sided through-hole PCB version will come in handy for future projects too. So, whatever you decide for yourself, maybe the following links may be of interest to you.
DIY PCB Manufacturing
I would like to add a Link to Mike Harrison's Site, who gives excellent guidelines to those of You who would like to make there own High Quality PCB's for this Project.
How to make really really good homemade PCBs - By Mike Harrison:
http://www.electricstuff.co.uk/pcbs.html
Note: And here You have the plagiarized copy of Mike Harrison's Site by the Indian Electronics Magazine credited to a rip-off artist called Indrani Bose in PDF-format:
How to Make Good Homemade PCB's - By Indrani Bose.pdf:
http://www.efymagonline.com/pdf/Pcbs.pdf
DIY Printed Circuit Board Using Photo Etching Method:
http://www.youritronics.com/diy-prin...tching-method/
DIY Printed Circuit Board (YouTube Video) - High Quality PCB at Home:
http://www.instructables.com/id/DIY-...circuit-board/
How to make PCB's at Home (Links):
http://free-pcb.100webspace.net/how-...cb-in-home.php
Easy Printed Circuit Board Fabrication - Using Laser Printer Toner Transfer:
http://www.fullnet.com/~tomg/gooteepc.htm
Laser printing of PCB's (Links):
http://on.blogdns.org/laser-printing-of-pcb.php
Hacking a Printer to Directly Print PCB's (very comprehensive discussion here):
http://www.cnczone.com/forums/showthread.php?t=30951
Currently, two Through-Hole versions of the PCB's are used, and the double-sided board has given the most problems, as also being the most difficult to manufacture for the Home Brewer. And here You have a few interesting links to DIY Through-Hole PCB manufacturing, that lubricates this matter like a soothing ointment on a sore butt-hole.
Acid Copper Through-Hole Plating:
http://www.thinktink.com/stack/volum...I/copplate.htm
PCB Through-Hole at Home:
http://www.colinmackenzie.net/index....4:pcb&Itemid=6
Through Hole (EDAboard Thread Links):
http://search.edaboard.com/through-hole-via.html
Enjoy!
Robert
