Delta Pulse
  • best way to trace metals
    What is the best way to trace metals?
    • I am experimenting with this circuit to slightly increase the tension of 7909.
      • Grand balance
        HI to ALL .Grand balance metal detector pulses in the works? Please explain.
        • Originally posted by perzo View Post
          I do not understand your English what is your native? write in your native anybody could translate it in English.
          • Hi jose, kt315 and ousama , many thanks for help
            • Originally posted by Jose View Post
              nice work kt315
              i was think that the voltage between E+ and E- should be so stable and requlated
              and i was think to make circuit that provide -10.6 by 555 TIMER AND voltgae multipler
              and requlator
              so if battery fall from 12.5 to even 11.6 volts this -10.6 still stable
              because 555 timer can be used give -20 volts from 12 volts and then we regulated -20 to -10.6
              i copy this idea from pulse star power supply circuit
              pulse star use requlated power
              i will post schematic soon
              i have question
              my question to any one have scope to see if there is noise from LM556 in the e+ and e-
              and ground?
              • take alook about this
                • hello people call me nataildo (measure), I am new to this forum and would like someone you take away a doubt.
                  I set up a metal detector delta pulse rx-71 100% it works, but I'm wanting it to detect small nuggets
                  gold I've done some testing with multiple coils made ​​by me only wanted to ally this distance and not interference from the ground. now thank you
                  • Originally posted by didarpm View Post
                    Hello Didarpm
                    Pulse Delta was not designed to detect gold nuggets. You can experiment with fast driving coils and decrease the delay time to improve the detection of coins.
                    There is much information in the forum as coils and decrease the delay time in the DP.
                    • please help me
                      Hi forum
                      yesterday i had finished my new delta pulse, but i was wrong solder the mosfet and ne556, so when i connect the bettery, i see afew smoke on mosfet area and delta died, when i look the smoke area, i see that two 1n4148 (VD8,VD9) is broken, i changed those and i use new 556 but since i have not new IRF840, only i turned it 180 degree ( true position) and connect the battery again; there is very very low sound in speaker and when i test IC's legs with multimeter, all of leg's voltage was 12 or 13 volt but only ne555 had some 5 volt.
                      i was not use coil.
                      this is my second delta and firs one work well. my electronic not so good so please help me to solve my problem. any info will be great help for me.
                      thanks in advance
                      • Originally posted by silver View Post
                        Hi forum
                        i was not use coil.
                        thanks in advance
                        Hi Silver
                        and hi to(Cyrus_ cilinder) great king korosh
                        as you said , you are beginner in electronic circuits ,delta pulse is complex project .
                        replace irf840 , add series fast fuse 500 ma with battery . coil DC resistance must be not lower than 3 ohm . without oscilloscope repairer not easy . I hope you haven’t other problems with delta pulse .
                        • Originally posted by aft_72005 View Post
                          Hi Silver
                          other help for you .
                          I remember there are good instruction with two language English / Persian in this
                          Thread , uploaded by Qiaozhi . Also read carefully KT315 and ivconic messages .
                            ...when i test IC's legs with multimeter, all of leg's voltage was 12 or 13 volt but only ne555 had some 5 volt.
                            Your problem as you describe it points to a bad solder connection or open (broken or burned) trace. I say that because 12V is the same power source all over the board. If you have 12V everywhere else but don't have it at the 556, well, what else could it be?
                            Whip out your multimeter, PCB layout and schematic diagrams, magnifying glass, and use your eyes!
                              Hi Silver
                              thanks a lot dear aft, i will do what you say, and i will post the result.
                              many thanks
                                yes, i read that, and i read all of this thered, only one question; how i can test transistors and diods and capacitors on board with multimeter? and i must change all of the ICs or not?
