Bulgarian 'PULSE STAR' (... close to Legendary one)
  • Originally posted by Falcon View Post
    Dirceu Hi, I would like to make a metal detector, but I'm an amateur at it, I would like your opinion on what to do, since we are "neighbors" can you help me? I wonder if the cost benefit is worth. My email address is -> [email protected] - I would like to speak in Portuguese (hehehe)
    Hi! Falcon.
    See your e-mail box, OK?
    DIRCEU
    • Hi DIRCEU
      i want to make this detector but i am laik pleas send mi to my mail is [email protected]
      thank yau
      • Hello all friends
        I want to make the metal detector.
        From friends who have made the metal detector like that from Ntaykh tell it to me
        The detector for metals with dimensions 50 * 50 cm to what extent has the power detection. (With a loop * 1 )????
        The sensitivity of this metal to gold and copper is how much? Is whether the high level??
        Please help me
        • hi all
          can any one post afull data on this project
          in a rar or zip file pleas
          part list a compleet pcb and the wrigt scamatics so that all the member can make the good md
          and some explanations on the vr's
          tc
          danny
          • Hi.
            Please can you tell me if this detector is a No-motion detector??
            • Hi Geo
              It's a no-movement detector (continuous sounds quiet coil).
              Jose
              • yes, Pulse Star BG is [non-motion=static=DC] PI detector like as [Delta Pulse=Sniffer SR-71].
                good luck, Geo
                • Thanks for your reply. I want a good PI detector to work with big coil. I made a coil 1x1m for the TDI but i have problem to pinpoint because it is a motion detector.
                  Maybe Carl knows any trick to make it no motion??????
                  Other way i will construct this detector....
                  • a help pleas
                    hi all
                    can any one plese post the compleet project
                    a good pcb without erors
                    the wright scamatics
                    the list of matirials or part list
                    and so on
                    i will be thankfull
                    tc
                    danny
                    • Hi Anatolij.
                      I attach here the text who you had post at the start of this thread.
                      Please can you translate what writes about 1x1 coil??
                      Thank you
                        Hi Anatolij.
                        Thank you
                        Geo this is in Bulgarian (not in Russian) language.
                        For 1x1m coil you use multi-wire phone cable with 36 wires inside. Cable length 4.2m.
                        I am sure that how to make PI coil out of multi-wires cable is very known to you (described more than once here on Geotech too).
                        Here you use 3 of wires together in parallel, so all in all you have 12 wires (12x3=36).
                        For bigger coils as 1.5x1.5m, 9 turns, you use insulated copper wire with conductor diameter of 2,5mm.
                          Thank you WM6.
                          Does it says about the diameter of the phone cable???
                            Thank you WM6.
                            No. There must be some standard for telephone wiring inside buildings. Not mentioned shielding too, so probably unshielded.
                            Maybe it was Centronics (printer) cable and not UTP. The same but more flexible. Like this.
                            http://www.blackbox.com/Store/Detail...EQN380%C4%82MF
                            • PULS STAR-G cil 1x1m.
                              Happy 2011! PULS STAR-G; COIL 1 m x 1 m ; 12 turns, wire 2 mm*, for Speaker
                              System, Silicone izolation.OK?
                              G.L.!
                              • Originally posted by georgi.g.zhelev View Post
                                G.L.!
                                Hi Georgi, nice to read something from you again.
                                You mean double speaker cable with both wire connected togheter in paralel or only single wire used?
                                Happy and successful 2011 for you.
