Bulgarian 'PULSE STAR' (... close to Legendary one)
    I heard the Ground Pioneer 4500 is the best.
    Or is there a better one?
    I heard Stinger II is the best:
    http://www.mikronbg.com/Stinger2.html
    • thanx WM6 for this info.
      And Mikron is from Varna, Bulgaria, very cool!
      Can you tell me the reason why it may be better?
      - depth?
      - discrimination?
      - price?
      - additional coils?
      - stability?
      - battery life?
      - production quality?
      - ground balance?
      - more adjustment possibilities?
      - something else important?
        - depth?
        - discrimination?
        - price?
        - additional coils?
        - stability?
        - battery life?
        - ground balance?
        Compare the technical specifications and you will get answer.
        • Yeah, they're good, but what do you think is special about them to make the Stinger II the best PI of bulgaria and perhaps of the whole world?
            Funfinder, a competent designed PI metal detector should operate with induction balanced coil configuration. Can you show a Bulgarian PI metal detector operating with IB search coil?
              Probably in advertising pledges.
                thx for your short-answers - they are very helpful.
                  No sorry, I can't, and I don't know how much better with discrimination, ground balance and depth an IB PI MD is.
                  Perhaps you know such PI with induction balanced coil or perhaps you will built the first of Bulgaria?
                    All those Bulgarian PI-s are based on pretty the same platform. Not only this, in most cases producers are the same too. Example: if you buy something from REX producer you will receive the bought packages from producer Mikron, - mean those different producers exist only in virtual on web, but not in real.
                      I agree, and all PI detectors without discrimination from Mikron are based on Delta Pulse and the rest with discrimination are based on PD3200
                      • Bulgarian colleagues reached point of better knowledge from all us here in local neighborhood, environment, there is no doubt in that.
                        So there is no need to question their knowledge and capabilities.
                        I can only seek infos from their works and learn from those.
                        But one thing is pure knowledge and quite another thing is marketing approach.
                        Most often; market is the main deciding factor, which decides about quality of some product.
                        People who never really tried to deal with that - usually are very ready to criticize somebody's else work and efforts.
                        I can only pay tribute to efforts and enthusiasm from Bulgarian colleagues!
                          WM6!
                          Please could you stop making every detector from the balkans worse?
                          You tried this with almost obsessed afford concerning the Jeohunter but with no success and now you want to drag the bulgarian MD-producers into dirt just because the Rex is somehow connected to Mikron.
                          Bulgaria has at least 6 or 7 different metal detector companies, those are not connected and they create very good products.
                          I know a reseller in Germany personally that imports as example the Vista RG 1000 because this is a not expensive, reliable, deep seeking and for very small items suitable detector.
                          And my bulgarian Blisstool LTC64 also is very good working - even alot better as the Fisher 1266-X.
                          I don't care if the PIs from there are based on similar circuits - after all that long time they are most possible improved and the people of the balkans have good talent in electronics!
                          They have the needed patience for electronical engineering (and you need alot of that!) and those are perfectionists while motivated through very nice treasures you can find in that countries!!!
                            WM6!
                            Where do you read this your babbling in my writings?
                              Hi Geo!
                              This is fantastic you know they bulgarian PIs very good so perhaps at least you can tell me if the Stinger II really is the best and why.
                              I'm not so shure:
                              One example:
                              You have to order an additional 36cm coil incl. holder for ca. 150 Euro but I would like a 50cm coil minimum and it should be inclusive because no one wants to be limited to a huge square coil!
                              and is this the max. depth PIs can reach? I guess not.
                              Depths of finding metals with searching frame 1,20x1,20m.:
                              - metal object sized: 10 x 10cm………………….180 cm. (5,5')
                              - 25 x 25cm…………………………………..……..230 cm. (7,5')
                              - 50 x 50cm…………………………………………..2,8 m. (9,3')
                              - 1 x 1m. ……………………………...……………….4 m. (13,5')
                              - Maximum depth for a very big metal object …..up to 6 m. (up to 20')
                              • @WM6
                                You forgot to quote the full line and Turkey is balkans, too.
                                WM6!
                                What do you really want?
                                First you advertise the Stinger II and next you write:
                                WM6: 09-12-2011, 03:40 AM
                                "All those Bulgarian PI-s are based on pretty the same platform. Not only this, in most cases producers are the same too. Example: if you buy something from REX producer you will receive the bought packages from producer Mikron, - mean those different producers exist only in virtual on web, but not in real."
                                This looks like you want that I shall buy the best but of not really good because somehow cheating PI detector producers!
                                And I wanaa have a real usable answer, not your cheap and unrespectful short"babbling":
                                You have one more chance...
                                "Yeah, they're good, but what do you think is special about them to make the Stinger II the best PI of bulgaria and perhaps of the whole world?"
