Bulgarian 'PULSE STAR' (... close to Legendary one)
  • Originally posted by georgi.g.zhelev View Post
    "1. GRОUND EFFECT > ZERO" ?? Land does not affect !
    2. Can you tell me who is the disadvantage of ligh version?? ..No analogue memory.I have not worked!
    3. Also why OP37 is not good for this detector??? It has very hight bandwidth and slew rate.
    btw... the 50us pulse at ne5534 (curve 5Ud21,,,d24) are similar to a 20khz signal so we need a bandwidth more than 40 Mhz for a gain of 2000. ... I TESTED,does not work well !! BEST IC (U4)...OPA 2132 ,LF357,OP27. (NO NE 5534)
    Thank you Georgi.
    Now it is time to fine adjust it and to make tests.
    If all will go OK then i need a nice casing for it.
    Also if all will go ok , i"ll try to connect the preamplifier of GS-5 (2 op-am in series).
    My best wishes
    • hi All
      is that someone can give me the pcb?
      thank you
      P.
      • Originally posted by g.s View Post
        MERRY CHRISTMAS TO ALL by health
        Hi, g.s, What happened to PS-G ?
        • Originally posted by pigeon View Post
          hi All
          thank you
          P.
          Take it and edit the errors. I found many....
          http://www.geotech1.com/forums/showt...234#post122234
            Мy result for PULS STAR-G : L diam. 30cm ; R= 0.7ohm induct.= 400mikr.H 1 EUR , AIR TEST ..=. 30cm : discrim ..(mikroampermetr)= 24cm ; GRОUND EFFECT > ZERO ! ;
            Hi georgi.
            My results with disc are the same with you. But i have not better results with audio. Anyway let it for later... Now i have a problem with curve 5. The width of pulse is 50us but at my detector is near to 10us. I think that 50us is very high and there is not any way to take pulse with more width. If i will connect dumper lower than 100R then the width of pulse is better but this is not good solution.
            I replaced the coil with the coil of TDI, it is 330uH and near to 3Ohm measured at the connector.
            Any idea???
            • Geo,coil IOW inductants , 300мкН ; high resistans r=3 ohm !!! NEW COIL: d= 30cm 450...500 мкН r= 0,7...1 ohm ; Change NE 5534 to OPA 2132 ,LF 357 , OP27 G.L.!!
                Hi Georgi.
                I replaced the coil with other (L=520 uH, R=0.8 Ohm) but the same problem. Anyway the big problem this time is the discrimination. When detects a copper then lights the green led. When detects a iron then lights again the green led and when the iron is 10cm near to coil then lights the red led. WHY??? The same with al. The same is happening and with meter. At ferrous the meter first going left and when the object is near to coil, the meter going right. Any idea?????
                • Finally i finished with the settings of pulse star. The depth is good, but not the discrimination. I had at my hands some copper and some bronze objects. Pulsestar see some of them as noble and few as ferrous. Tried all the items in delay from 50us up 200us and note the depth of each. Up to 200 us there was no apparent decrease in depth only to noble, or only to ferrous objects in order to be able to avoid them. In addition to 200 us the depth was reduced by 35 ... 40%. So i will deal again with my TDI
                  • ОК Geo G.L.!
                    • Hi to every one.
                      I search about part list of puls star BG and the coil(both of them) PCB correct and explan about them.
                      epecilly for coil & everi thing you think its necesery.
                      excuse for my english
                      • for exampele what can the ps-g sensivity depth?Maximum depth is how?
                        whats the different between ps-g ps-g light?
                        I waiting to for your answers
                        • This project make only illusion...
                          • WHYYYYY???????
                            I want to make that?
                            what is your reasons?
                            it is a non motion? correct?
                            I want to use that in plain &...
                            • hi to every one
                              I waiting.;.....................
                              • Originally posted by scs View Post
                                Hi MIG21 why do you think so?
