Bulgarian 'PULSE STAR' (... close to Legendary one)
  • #61
    3 meters on ramka of size 1 x 1 meters
    5 meters on ramka of size 1,5 x 1,5 meters
    target is 0,5 m of diameter
    maximum is 8 meters of depth
    • #62
      Hi kt315,
      Thanks...
      Did you build this device?
      which is latest PCB and schematic of pulse star...
      anyone build this device... please guide us to building it...
      • #63
        Did anyone build this PULS STAR G ?
        what about it's performance ?
        • #64
          PULS STAR-G
          HI,GOLDENSKULL. I MADE "PULS STAR-G" 2002 , and repeated 2008year.
          • #65
            PULS STAR-G
            "PULS STAR-G" FRONT PANEL
            • #66
              Hi georgi.g.zhelev,
              Please tell us about it's performance ? (depth and disc) ?
              • #67
                PS-G
                Hi georgi.g.zhelev,
                PULS STAR-G COIL diam. 20 cm; TARGET 1cent USA (18mm)
                SENSIVITY=30..35cm
                DISCRIM. =25cm graund efekt =zero
                • #68
                  PulseStar-G
                  Dear Friends
                  Has anyone Part List for PS-G?
                  GoodLuck
                  • #69
                    Hello to all friends
                    I built pulse star bg.
                    The launch of this circuit was difficult. Normally without any voice coil circuit is slightly wet fingers, but when I Asylatvr transistors 555 and alarm system to Mykshm.
                    When the coil 20 cm can be connected to the metal detector q4 is extremely hot and burns. Profile coils is this way: 32 round wire diameter of 0.50 to 20 cm.
                    I'll guess that the problem is the coil.
                    Metal detectors instead of the 2n2646 transistor ujt I use. I want to know that this device provides a problem? Base sequence in this transistor pcb do not know Please help me.
                    Tl072 use instead of my 1458. This problem does not and I do I replace them?
                    Please help me solve this problem, please
                    With respect
                    mesyna
                    • #70
                      PS-G
                      Hi,MESYNA!! very well !! I help you. You build PS-G or PS-G light ???
                      Please schematic.
                      Good Luck!
                      • #71
                        Please schematic.
                        Good Luck!
                        tank you my friend
                        this is my schematic
                        • #72
                          PS-G COR.
                          PS-G corect.
                          • #73
                            ps-g
                            coil diam. 20cm : 32 turn. 2 x 0.51 R= 1.2 ohm !!!
                            mesyna,good luck!!
                            • #74
                              TANK YOU DEAR georgi.g.zhelev
                              The relationship between the base D in Q4 with the coil is cut. This is true?
                              • #75
                                пс-г
                                Тhis is no true !!! I deleted . Q4 Dr. conect. L ( R6 and L con. paralel) ok?
                                excuse me for my very bad english.
