Bulgarian 'PULSE STAR' (... close to Legendary one)
  • corectClick image for larger version
Name:	DS0018 mohandes ,disc., oscil s nadpisi.bmp
    • ok
      today i try to fix TP points but i just can set TP5 on 0.6v
      thanks
      • hi georgi
        just tell me my X,Y,Z out put have correct waves?
        X :
        Y:
        Z:
        • hi
          i need the waves of X,Y,Z of 4053 ,please
          mr georgi my coil can be 450volt p-p ,is it ok?for biger voltages i should reduce the coil Inductance or increase R parallel to the coil???
          • for more voltage amplitude you have to encrease PULSE WIDTH. also you need to change your mos-fet IRF740 on another transistor type. because max peak voltage for IRF740 is only 400V. you have reached the limit with 450V and will NOT get MORE.
            • [QUOTE=mohandes;177952]hi
              mr georgi my coil can be 450volt p-p ,is it ok?for biger voltages i should reduce the coil Inductance or increase R parallel to the coil???[/QUOT
              mohandes,Did you read what I write you? SEE # 515!!
              • [QUOTE=georgi.g.zhelev;177962]
                Originally posted by mohandes View Post
                hi
                Yes i read it and all is ok( i print it and save all figures in my mind ).please see #535 and#543.
                when i connect to third board (TP points my means )i can just adjust one of the them and it is TP5(adjust by Delay or Rv3 and Rv9) to 0.6volts.
                but Tp3 dont fall down to-2.9volts , so can i change the Rv7 to 20Kohm pot??????????
                explain more : when i change Rv6 or PPS or FCY can be adjust it but pin6 ne5534 not in -0.2volts , so what am i do?
                best sens for delay on 50mks or 100mks?
                and 450volt is ok ?
                • [QUOTE=mohandes;177971]
                  and 450volt is ok ?
                  • hi georgi
                    just tell me why when i return Delay pot(U2-pin6)all TP points changes ????please
                    i set tp and then when i return it all TP go fault
                    • Originally posted by mohandes View Post
                      hi georgi
                      This is normal . mohandes , this shematic is no for you , You do not have forces to do Puls Star -g . PLEASE STOP PROJECT PS .
                      • Originally posted by georgi.g.zhelev View Post
                        OK man
                        i design again the third board like your schematic and get find,all TP point are ok and set.
                        just LEVEL meter not work(very very bad) and about the discrimination i should test it tomorrow
                        and both Led(red and green )always on and off!!!!!!
                        my coil is 500mkh and 2ohm ,R parallel is 220ohm.
                        all waves like # 515
                        thanks man
                        • for Georgi
                          hi Georgi
                          now i want complete this. just tell me this pcb is ok , or no .
                          or any one can help me
                          http://p30up.ir/images/ryvil2xg5sy0pd38pe0.rar
                          • 我已经做好了脉冲星,但识别并不是非常好,电路中有非常多要改动的地方,我可以给大家一些解答
                            • Originally posted by fengzhai01 View Post
                              your chinese hieroglyphic is PERFFECT! to my sorry it is unreadable (((
                              • Strange, but google can translate this better than most other languages:
                                “I've done a pulsar, but recognition is not very good, the circuit has a lot to change the place, I can give you some answers “
