Greetings. I have a Felizjoo. You can adjust frequency, pulse width, delay, speed, etc... It has Automatic and Manual Ground Balance. If you want to use it to search for gold nuggets in highly mineralized soils you should do your own tests with various types of coils.
I recommend you can make a double Monoloop coil, a small DD coil and a Super DD.
If you want to play it safe, the GD4 detector, even the Hammer would be very good options but coil design is critical in these red soils with very high iron content.
Also your motherboard case should be wrapped in a faraday cage to eliminate as much noise and interference.
Excuse my poor english
