This is a good project to learn from, tap into an old SD2000 and switch between how it functions on its own and experimentally through a development board, eventually you will exceed the SD2000 operational performance and use the information to build your own detector.
Getting to know PI with nucleo board and SD2000
Originally posted by detectormods View PostThis is a good project to learn from, tap into an old SD2000 and switch between how it functions on its own and experimentally through a development board, eventually you will exceed the SD2000 operational performance and use the information to build your own detector.
I am personally very satisfied is it good I don't know, if the original sd 2000 can do better ?
- Likes 1
Probably removed the GB method? Most soils in Europe don't need ground balance. I have few SD2100s /similar to SD2000/ and these are a bit noisy.
If you came up with something to remove chattery behavior you can squeeze in some more depth. Some improvements in the preamp perhaps?
Anyhow on the topic, isn't the TX feedback going to be problem for nucleo? Or you suggest stripping the snubber tx circuit and limiting the TX voltage with simpler method thus keeping the timings easier to achieve?
- Likes 1
Originally posted by eclipse View PostProbably removed the GB method? Most soils in Europe don't need ground balance. I have few SD2100s /similar to SD2000/ and these are a bit noisy.
No geb still plays his role, but you gave me the idea that geb is not needed in some places here. The frenzy comes from positive 5v volts, the preamplifier must still be like ad797 or something even better ,I can increase the gain from 47 to 100 because it is quiet ,if you look at the power supply signal +5V or 62KHZ there are sudden jumps at first I thought it was the generator however, everything is interconnected the problem is not the generator because I also measured the signal on the digital one with the processor I got peace of mind by playing around a bit with moving the second sample away from the first on all three channels and of course +5v created a little differently in the power supply..
- Likes 1
Hello friends, I live in Iran and there are many problems here. Can you email me the files for making sd2000 or sd2100? Thank you [email protected]
Originally posted by Orbit View PostWho wants to play with the sd 2000 or 2100, here is a mod for similar discrimination as on the tdi, the led on the iron dims and on the high conductors it lights up more.
