Pro Xl 500
  • Pro Xl 500
    I would be glad if you could help my masters I need to lay the pcb of this plan
    Hi haylaz0036
    you have the schematic already. Why do you not make a PCB by your self? If you don't know what software to use, then use Kicad. Kicad is a powerfull free software package. You can download and use Kicad for free. Here the link: https://www.kicad.org/download/windows/
    With Kicad you can draw the schematic and make the PCB layout.
      I would advise you to use the Sprint Layout program. You use the function: Extras-Scanned copy-load bitmap and indicate the path to your picture on the board. The photo must be in .bmp format.​ From Options-macro lab, you take the macros of an integrated circuit and impose it on one of the ones in the photo. Then you change the resolution until the pin locations match. Then, with the drawing tools, repeat all the connections as they are in the picture.​
        You thought you have lay file pcb will take the suspicion to redraw
          Enjoy it.
            Thank you very much, my dear masters
              You are welcome.
              Check before making pcb please and I'm waiting for your video after you finish the pcb.
                Hi to all check NE5534 PIN 2 AND PIN 3 DIOD ZENNER 1N4148. I SEE PROBLEM .
