THE ELUSVE 1us TC TARGET
  • #76
    Yes, it is a single frequency compensator, over 95% compensation for sine wave, for pulse I think it will be about 80%.
    • #77
      my guess (based on info you provided) , you are using 2 wire audio cable with the shield, for Rx one wire and ground for Tx second wire and ground,
      You are offering a circuit for a VLF detector = for any balancing
      The coil cable is composed of 4 wires + shield. 2 wires for TX, 2 wires for RX, the shield of the coil is connected to the shield of the cable. Cheap cable from ailiexpess.
      I als bought a similar cable with 5 wires, in case I want to try with a center tapped RX.
      • #78
        then how come you have = High current in the cable induces a (relatively) high current in the shield. = ???
        follow post #70, I am not want to guessing any more.
        • #79
          [ATTACH]n419523[/ATTACH] Here is the last breadboard experiment of the preamp. with a gain of 15x47. The black trace on the scope shows the signal of a 25x25mm kitchen foil. I will now starting to draw the layout of the Preamp PCB. I will also end this thread and continue on the AMX RX thread where is belongs. https://www.geotech1.com/forums/foru.../408950-amx-rxClick image for larger version
ID:	419524 Click image for larger version
          • #80
            capacitane/inductance calculations (mogami.com)
            The mogami​ inductance calculator can give you an idea about inductance in cables. The Mogami cables are of the best in the world.
            AC resistance of parallel conductors (mogami.com)
            • #81
              calculations, simulations are not the same in real world, have you measured the shield to grounding capacitance ?
              • #82
                check the AMX coil thread
                • #83
                  you have a problem with shield not me.
                  • #84
                    When two "guru" members dialogue, the practice have to be the true of last instance! The practice show that the perimeter of the target gives the strength of the received signal in PI system.
                    • #85
                      But both of you are right- the type of the cable and right connection to the MD's box is very important especially in fast PI.
                      • #86
                        I continue to work on this problem. Now, I check the results with using of separate Tx end stage and first Rx stage on one small board inside searching head.
                        • #87
                          This solution reduced hand's influence on the connecting cable but not absolutely
                          • #88
                            You mean the surface area. Correct, if the area is reasonably flat.
                            • #89
                              It needs the right cable. I dont know of any better way than "trial and error" to chose the right cable. I must have tried 100 different cables, including many cables I assembled myself.
                              • #90
                                Hi Tinkerer,
                                The only current flow that should be on the cable shield would be due to the capacitance of the coil shield to the TX coil and the capacitance of the TX cables to the cable shield. This shield current should only be present during the fly back pulse, it can be a up an amp or more depending on the total shield capacitance and the size of the fly back voltage. This shield current may only be an issue if you are planning to take RX samples during fly back for target ID.
                                Or is it something else that your seeing.
                                Jeff
