One more variant to create PI MD with reliable Fe reject
  • #61
    I use KiCad 8 after developing the schematic and PCB, I will post it
    • #62
      Hi hunter63,
      If you will developing PCB, use please revision F1 . This solution use two 18650 LiPo accumulators and only 10 integral schemes. Also this solution use static searching - this is important for relative heavy searching head.
      Attached is the schematic of this revision.
      • #63
        Hello How sensitive is the detector, what is the smallest object it detects and the range of power supply will be determined by the DC/DC converter powered by Powerbank and PWM stabilizers, best regards​
        • #64
          Hi hunter63,
          PI+M DET. BALANCE 5 is designed for objects bigger than 1g. Not for grain weight objects. Power supply is from two 18650 LiPo accumulators. The range of the voltage is 6V-8.4V. No PWM DC/DC convertors in "Fe" mode. In this mode the detector have to be absolutely quiet - for max sensitivity in this mode working as gradiometer. In "ALL metals" mode works only one DC/DC converter for -32V.
          • #65
            The construction of the searching head (two RX coils) allows max deep of appr. 50cm for 50x50mm plates and 80cm for coca cans. As it it is seen by the name of this detector, It is balanced project between size of the objects and the deepness'.
            • #66
              The main advantage of this project is using of magnetometer connection of the two RX coils. This give 100% sure result that the object is "Fe" type when the detector react in "Fe" mode. No false "Fe" reacts on color metals in some cases.
              • #67
                Hello
                You have a message on PM.
                A magnettrometer is an arrangement of protons along the Earth's field (the core medium is distilled water or kerosene)
                I suggest that this is some kind of gradiometer, but I must admit that the range of this device is not as large
                • #68
                  Hello,
                  A proton precession magnetometer is only one type of units for measuring of the magnetic field. Have many other types of magnetometers. Induction coil is one of the unit for measuring of the magnetic field.
                  Using of two induction coils in gradiometric connection is also possible for way to react on magnetic field. All metal targets with Fe contents made second magnetic field as reaction of primary magnetic field of the Earth.
                  But yes - you are right - the sensitivity in "Fe" mode is less than in "All metal" mode. But when detector reacts on the target in "Fe" mode - it is 100% sure - the object haves Fe content.
                  • #69
                    Hello
                    specify what minimum object is detected, what depth, probe stability, I am thinking about a new input circuit, that's why these parameters are needed​
                    • #70
                      The beer's caps are recognized sure at 15cm. This spend many efforts in real fields.
                      • #71
                        Hello Very little,,,, I have to run a simulation, something is wrong, tell me how the probe behaves when touched
                        • #72
                          In reality, it is not possible to detect objects as 1grain (appr. 1/20gram) on 5cm simultaneously. Usually this size is recognized at 15-25mm with best detectors. More big objects are recognized on bigger distance.
                          What really is your aim? Give more information for size, type and for type of soil.
                          • #73
                            The reaction on the hit will depends of how solid you will made her. And for simulation of this case - you have to be a mag!
                            • #74
                              See my answer on your PM message.
                              • #75
                                There is nothing on PM
