What detector or generation of detectors am I describing?
  • What detector or generation of detectors am I describing?
    Separating Frequencies by Time:
    • The detector transmits two pulses with different lengths.
    • The received signal is sampled at specific moments after each pulse.
    • High-frequency components decay faster and disappear in later samples.
    • This allows separation of high (H), medium (M), and low (L) frequencies based on the sampling time.
    Subtracting for Signal Isolation:
    • The H component is isolated by subtracting the M and L components (adjusted proportions) from the initial (HML) sample.
    • Similarly, the M component is isolated by subtracting the L component from the ML sample.
    • The L component, containing ground signals and low-frequency targets, remains separate.
    Ground Balancing:
    • The L component includes unwanted ground signals.
    • A portion of the L component is subtracted from both the H and M channels to compensate for ground interference.
    • Early models used a manual ground balance control for each channel.
    Dual Pulse Advantage:
    • Different pulse lengths create ground signals with different decay times.
    • A target's response might be notched out in one channel due to ground cancellation but remain visible in the other channel with a different pulse length.
    • This redundancy helps avoid losing targets due to ground signal timing coincidences.
    Signal Processing:
    • Positive and negative target signals are rectified using full-wave rectifier circuits for consistent polarity.
    • A voltage comparator selects the higher-amplitude signal from both channels (H or M).
    • The chosen signal is then used to modulate the audio output.
    Well I figure it will be a new generation.
      If we had a time machine.
        Are these yours or m*****b's ?
          I condensed the workings of the SD GP into point form, I am doing a talk at one of the Universities in a couple of weeks, just testing it out.
            It looks to me that you are describing the basic functions of my AGD detector which basically does what you describe but with a single pulse.
              ​Sounds like BBS to me.
                Hi Carl,
                What is "BBS"? As relatively new in this forum, my dream is to read full names of the the topics.
                  Hi detectormods,
                  For me, your idea is too similar to SD2000, but will be more simple solution by using of software treatment.
                    Hi AMA,
                    "I have mostly completed my design work on my analog metal detector which is named AGD23-2 but will be updated to AGD23-3 for the final version."
                    The new ideas of every real artist (engineer) never ends - please continue to post your new ideas!
                      Originally posted by Detectorist#1 View Post
                      Hi Carl,
                      BroadBand Spectrum, Minelab's multifrequency method (Sovereign, Explorer, E-trac).
                        Thank you Carl!
                          Hi detectormods,
                          If you don't know what type of detector will be designed according your new idea - the result maybe will be - the new marriage is a triumph of hope over the reality!
                            Hi detectormods,
                            The designs he is describing are nearly 30 years old and are still valid.
                            US5576624_Candy_SD.pdf
                            US5537041_Candy_Sov.pdf
                              Hi Altra,
                              If this idea is 30 years old, way detectormods asks - what type of detector is this? Maybe hi not know well forgotten ideas?
