The underwater SECON UWM20 was sent to me for repair - https://ebingergroup.de/wp-content/u...ffekt_engl.pdf ; I could not find a manual, there is very little information about this model. https://buergerrechtler-micha.blogsp...gerat-mit.html. Extremely simple to use and superior sensitivity - opinion of the owner. https://www.djlaan.nl/secon-uwm-20-w...inter-detector - ,,The sensitivity of the detector can be adjusted by turning the adjustment ring on the front of the handle'' - this got me very interested...- what is the principle ?
There was no radiation - I disassembled it - white paste on the front of the board, near two electrolytic capacitors ... I replaced the key IRFD9220 because it was covered with a white paste (cuts the current through the coil) and it worked immediately. The adjusting ring is very close to the coil
! - it has an average diameter of 13 cm. . A plate of magnetic material is placed on the inner diameter of the adjusting ring - it strongly sticks to a magnet ! , it was not covered with rust. The plate is 12 mm wide, its diameter is 44 mm and has the shape of an arc -180 degrees - it covers half the diameter of the adjusting ring. I measured the detection delay – about 120 microseconds
!!! How does this miracle register coins and rings at about 20cm and small gold crosses at 3-5cm with this huge delay?!? .Brilliant solution by Ebinger ! The whole secret is in the arc of magnetic material, but what is the principle?
