GoldScan-6
  • GoldScan-6
    Hello I am resuming the topic of GoldScan, as I promised, I am posting a freshly developed diagram.​
    You might want to consider a different power supply configuration. The AM10CW-2405D-NZ are very expensive and appear hard to find. Maybe there is an alternative brand?
    https://www.findchips.com/search/AM10CW-2405D-NZ
      Hello
      They are not very expensive, around 16E, you can easily buy them at TME.EU
      You can use a lower power one, much cheaper, but I used it with reserve. Do you have a BT.Test diagram?​
        What is a BT.Test diagram?
          Hello Altra
          Battery Health Test Regards​
            Okay, no I don't have any battery test diagrams. They can be tricky and depend on the battery type being used.
              For power supply, I plan to use PowerBank 20000mA/12V
                They are not difficult, usually on two transistors, three LEDs, a zener diode and that's it
                  Hi hunter63,
                  My comments: With the first delay of 10-20us forget about small objects. This project is like wearing a boxing glove to swat flies - but without success! Too many expensive parts for very disappointing results.
                    Also using of ADA4610 as input RX stage with 30nV voltage noise at 2Hz will reduce drastically the distance of recognizing of the targets.
                      without being sure, I think the resistances should be reversed​.
                      R99<>R95 R100<>R96
                      Nice work ....hunter63
                        Hi Xtrem,
                        You are right - the values of R99-R95 and R100-R96 have to exchanged. Also Q9 and Q10 have to be connected in reverse - emitters and collectors have to be exchanged!
                          The diagram provided is a prototype and the audio has been completely changed. Now I'm busy with field service, I'll post the corrected errors in the evening, thanks for the analysis, best regards
                            Hello
                            I am sending upgraded audio​
                              Which version of GoldScan did you build, version 5 is based on Whites TDI, I saw this detector at a rally and I disagree that it has a poor range, there are videos with Goldscan 5 on YouTube, the ranges are reasonable
