Pulse Star II Pro (digital version)
  • Pulse Star II Pro (digital version)
    I'm trying to help someone who has a PSII-Pro that appears to be defective.
    First, does anyone know if the analog circuitry is the same between the PSII (analog) and the PSII-Pro (digital)? The PSII-Pro has 2 PIC micros which I assume replace a bunch of discrete logic in the old design. But it still appears to be a more complicated design, leading me to believe that even the analog circuitry is quite different.
    Second, does anyone have a schematic for the PSII-Pro? I am only interested in repairing this detector and, if required, would promise that no one else gets the schematic. You can PM me on this.
    Third, does anyone know how to contact Thomas Breuer? I tried the email on his Pulse Star web site but no response.
    Fourth, here is the problem: I can turn it on, press the retune switch, and adjust tuning to get a low motorboat threshold. And then sometimes it continues to work just fine. But sometimes when I release the retune switch, after a 2-3 second delay, it suddenly "rails out" like there is a big metal target in front of the coil. And it will do this as soon as I turn on the power. I can press the retune switch and it returns to the motorboat threshold until I release it. My assumption is that the retune circuit (usually an analog sample-hold) has maybe a bad capacitor but without a schematic it will take me a while to find it. And, like I said, sometimes is continues to work; I've left it sitting with an idle threshold for hours with no problem. Anyone else ever seen this problem?
    Hi Karl! Pulse Star 2 and Pulse Star 2 pro work exactly the same! I had a PS 2 pro, I didn't copy it in real search, the ps 2 pro seems a bit more unstable than the ps 2. The same thing you describe happened to me with a PULSAR 3 with LCD, the clock works normally and suddenly the sound is like when it catches a big target! The problem can be from the resistor in the coil if the resistance has increased due to heating! Then I would look at the input diodes, if one fails, that phenomenon happens! I would monitor the stabilization so that it does not occasionally lose voltage, I think it uses the same stabilization as ps 2 lm 324! Is there a sudden loss of voltage that should be 10v! ps 2 has three voltages, the cd 4053 is powered by 11.8v, as well as two IC lm 358, the other circuits are 10v, and only the cd 4046, if I remember correctly, is powered by 5v!
    As for Thomas, a friend told me that he was seriously ill during the corona virus, I'm afraid he can't contact you..
      Thank you, Orbit, great information! Hopefully Thomas will recover. Do you know how old he is?
        Hi Carl! I will let you know next week I will send you a private message, Thomas or his son visitors my friend. I will give you feedback!
