PI discussion
  • PI discussion
    There is an excellent discussion on PI detectors at the Findmall "Classroom" form. It was intended to be a how-to class for users but has turned into detailed technical and design issues, due to the fact that Eric Foster is participating.
    PI Classroom
    Re: PI discussion
    I recently built the Mark Stuart P.I detector. As stated in an earlier post, it appears that VR-1 will not operate as shown in the schematic. In addition, IC-4 does not appear to have a 9V power connection, on the schematic, or on the PCB. Has anyone else built this board?. Any suggestions or help appreciated. thanks.
      Re: PI discussion
      Looking at the PCB IC4 has pin 7 connected to +16, not pin 9 to +9v as the schematic indicates (there is no pin 9!). Conversely, the coil is connected to +9 on the PCB, not +16.
      I redrew the schematic from the original which was too poor to post, so I need to check the original. In any case, the document needs fixing. Thanks for letting me know.
      - Carl
        Re: PI discussion
        Are there any changes to be made to the Mark Stuart PCB? any websites or further support for this design? thanks
          Re: PI discussion
          Other than what I've posted, I don't know. Mark Pauls came up with the PIC code, and Magenta still sells the kit (I guess). A few people out there might be messing with the design. I can fix the PCB if there's an error.
          - Carl
            Re: PI discussion
            Was the PCB made from the schematic?, which came first? if so it would explain errors on the board. Any way to get a copy of the original schematic? thanks
              Re: PI discussion
              I'll dig up the original schematic and post it. Might be this w/e before I can get it as I am heading to Atlanta today. But the PCB normally follows the schematic.
                Re: PI discussion
                Hi Chris,
                first sorry for my bad english...
                I built Mark Stuarts PI-Detector:
                1. The schematic has mistakes
                2. PCB is okay.
                3. VR1 doesn't work ! Don't use it, instead use VR2 for sensivity(10-Gang-Potentiometer)
                4. The pic-file has mistakes and didn't work.
                I fixed it.
                5. In the pdf-file are not descripted all the
                features of the pic (for example adjusting
                receivetime, pulse time and so on by push-switches.
                Please send me an email if you want to have the corrected pic-file and schematics.
                Bye
                Roland
                  Re: PI discussion
                  Hi Carl,
                  your site is great !!
                  Where do I find Mark Pauls' new file pi84-4r.asm ? I only find his additional hints.
                  BTW Mark's email-adress doesn't work.
                  Thank you.
                  Greetings
                  Roland
                    Re: PI discussion
                    The latest version I have is on the Stuart page. Click on the link for "PIC Assembly Code" which is actually rev 4.
                    - Carl
                      Re: PI discussion
                      Roland I tried 2X to email you, and server said message was undeliverable. Yes please email me any revisions on circuit, hex file or any other info regarding stuart PI. I am glad to find someone else who has built this detector. I got it working using a hexfile sent to me by Mark Pauls, and revision to op amp input circuit, however I have had mediocre performance.
                      Thanks Chris
