Anybody used a 16f877a pic
  • Anybody used a 16f877a pic
    Have you ever got a 16f877a to work
    did you have to use an external crystal ?
    thanks
    Hi 6666
    I did many years ago. What kind of problem are you having? Those chips only used external crystals or oscillators. No internal oscillator.
      thanks
      Yes, I've used the PIC16F877A successfully.
      There are several oscillator options available, and a set of configuration bits is used to select various options.
      Search for: "REGISTER 14-1:CONFIGURATION WORD (ADDRESS 2007h)" in the datasheet.
      Bits 0 and 1 are used to set the oscillator type:
      00 = low-power crystal
      01 = crystal/resonator
      10 = high-speed crystal/resonator
      11 = resistor/capacitor
      The resistor/capacitor is the low-cost option for timing insensitive applications.
        I also have used these PICs years ago.
        As Altra said, no internal oscillator so must use external XTAL, resonator or oscillator.
        There are newer PICs that are pin compatible with internal oscillates.
          Neither of the above statements is true.
          I have used a PIC16F877A in a timing insensitive application using the RC mode (does not require a crystal). I used R=3K3 and C=22pF.
          The allowed range is 3k <= R <=100k, and C > 20pF.
            Thanks guys for your help, late last night I was working on a example code that lead me to believe the PIC16F877A had an internal INTOSC block, but it doesn't, and i thought my pic was faulty, however it can be configured as RC or crystal/resonator only . The example article made no mention that external parts (xtal) were required and i got a bit confused reading the data sheet late at night. Always something to learn.
              Yes, you are correct. A XTAL is not needed just an RC to get an oscillator.
              Fine for Non critical timing.
