Little help :D
  • #76
    1,2,3,4,,,,,,,,
    Hi eessoo
    Congratulations on the third and expected fourth.
    -Do you have one working and the two do not work Compare between three will reach a solution.
    -Read attention in reply#59 by maiki.
    best time
    j.
    • #77
      i replaced the ne555 and it worked
      • #78
        Isn't it time you purchased a dual channel oscilloscope so that you can troubleshoot logically instead of guessing?
        • #79
          i can't afford one
          but i can access one
          i just don't know how to use it
          and i'm in mechanical engineering so i don't really understand how this metal detector work
          • #80
            Originally posted by eessoo View Post
            i can't afford one
            For a good explanation of how PI detector work you can read Carl Moreland's Hammerhead article located here .
            Instead of 74HC221, Surf PI uses CD4093 to generate sample timing. So, look at the app notes in the attached datasheet for an explanation of how the CD4093 can make a one-shot multivibrator.
            • #81
              i have a question
              what type of coil connector should i use??!
              tell me everything about it because i can't find it
              • #82
                • #83
                  thanks
                  what about the cable it self? anything special about it?
