Tesoro Cibola
  • #46
    • #47
      Many thanks,ivconic.
      • #48
        Great job ivconic!
        The second half of LM393 can be used to indicate the low voltage power supply.
        Best regards,
        GSL
        • #49
          ivconic excellent job.
          What software do you use for drawing the scheme? regards
          • #50
            http://www.expresspcb.com/
            • #51
              R37 (2.7m) must connect with pin3 ts272
              • #52
                Correct!
                That does not affect Disc mode and that's why i haven't noticed any problems.
                I will correct that.
                Thanks!
                • #53
                  Here is corrected:
                  • #54
                    Hello Ivconic,
                    One thing may be interresting to be tested is to use a MAX1440 instead of the 7660.
                    I've succesfully used this chip on a electric violin preamp.
                    The MAX1044 has got a Boost pin to make it run at higher speed (6 times) (without external sync).
                    You can ask some samples for free directly from MAXIM : http://www.maximintegrated.com/datas...7/t/or#Samples
                    Hugo
                    • #55
                      Iv, you are Not right when take the schematics, the layouts, and share here WITHOUT REFERENCE ON AN AUTHOR
                      from this moment ALL AUTHOR RELEASES will be ONLY MARKING! because your unfar politics
                      read MD4U about yourself, what people write about you.
                      • #56
                        No need to read - it was a joke
                        • #57
                          KT315 what are you talking about!?
                          I never ever claimed that it was my schematic! But pcb is my draw, be sure in that.
                          I don't know from which origin schematic really came, but as far as i am concerned: everything what's posted already here on Geotech belongs to EVERYBODY here!
                          And i have FULL RIGHT to play with schematic, add more components on it, susbtract as much as i want componentes from it, use only a part of it, use whole if i want etc...
                          Just as anybody else here.
                          Besides; Cibola is property of Tesoro, Giffords! Remember!?
                          I hope that you actually related your funny remarks meaning exactly on Giffords as authors, right?
                          Next thing you should do is to place "Unofficial copy of Gifford intelectual property" label on King Cobra boards that you are selling here, right?
                          Once you do that: you may have some rights to preach here on such subjects.
                          Cheers!
                          • #58
                            Oh i don't mind either way. It's been a while since i visited that forum.
                            Don't have a clue what's going on there.
                            Problem is because i don't understand Russian well and that's why i don't come there oftenly.
                            Schematic is posted here on Geotech and that's when i saw it for the first time.
                            So i was interested to try it. Didn't have bad intentions at all.
                            If my posting here is a problem than i am sorry and will not come here again.
                            Good bye!
                            P.S.
                            I will ask administrators to delete my posts from this topic.
                            • #59
                              I do not want to delete any posts in this thread, as I feel Ivconic has made a positive contribution to this discussion. In my opinion, I very much doubt that any schematics were posted here intentionally without giving credit to the originator. I have several schematics in my own archive which are also unmarked, and I have no idea where they came from. Anyway, the one that was posted here was a modified version. Remember also that Tesoro originally designed this circuit.
                              • #60
                                Hello Ivica,
                                Think it is nice work from you... and that you put it here on Geotech is great !!
                                So not remove it ! it is a nice new project !
                                Best regards
                                Ap
