ELYAPIMI PLL DEDECTOR
    Nice work!
    I see differences.
    I was in doubts about some wirement also.
    Especially there at BC639.
    Luckilly that part is easy to correct even later on prepared pcb.
    Have you made pcb?
    I don't like the long one so i made my own, bit smaller.
    Cheers!
    So far I have not made the PCB for lack of time, but soon I'm going to get her. The BC639 think it is not a problem. Whenever I get time I will make the PCB and I will post here a video with the results. For now I have to buy some IC that I need and I will start to mount. Greetings.
      Originally posted by scs View Post
      Weak generator and high gain. Only for light soil .
      no. power dedector silver and gold senst.
        Several reasons. Kudos to your patience though.
          Originally posted by cnckecgo View Post
          very sensitive for small target 0.35 gr 12 cm 2.5 gr electron coins 25 cm
          what's the size and thickness of the electron coin? Is this in air or in soil?
            Mysia. Kyzikos Electrum Stater. Wild sow standing left on tunny fish left / mill sail incuse. 2,5 gr elyapımı detektor senstive electrum
              cnckecgo thank you.
              Research and I wish you continued success.
              like a nice circuit.
              Will do as soon as possible.
              galaksi.
                Originally posted by eduardo1979 View Post
                Here is mine. A month ago I've drawn and now I will test it. Hope it works well. Greetings.
                eduardo1979 Is this your design?
                  Yes, with some modifications.
                    eduardo1979
                    In your schematic I see that you are useing a simple LM7809 and two 10K resistors to form a virtual split power supply.
                    What is the regulation like with such a simple power circuit ?
                      eduardo1979
                      This voltage divider works great and no need to use an operational amplifier. I've checked all my projects and works great. The resistors have to have a tolerance of 1%.
                        You gotta draw the pcb of this schema eduardo
                          Thanks eduardo1979
ID:	334445Enjoy if you like it.
                            Check it before you make it.
                            I have check it but I am not perfect.
                            Grt Nakky
                              bravoo nakky:
                              Eduardo , waiting for your interest about the schematic with this subject for revealing a good project
                              this detector is very stable.not giving false signal,working good at minerilized soil and very sensitive for tiny parts and money
                              how can get better performance by changing design and some parts ?
                                Dear Eduardo I am waiting for help about modification of elyapımı to get better performance.Pls help to modification
