Gravity Location and Gravity Resonance
This topic is closed.
  • Gravity Location and Gravity Resonance
    ”.Making the Roman Rod will provide you with a really working Gravity locator.
    This is the actual Physical Radiesthesia. The achievements of the ancient geology explorers will be yours.
    Be sure that you do not need any kind of extra sensorial abilities, in order to compose the device.
    The locator functions on the basis of the gravity interaction and the Gravity resonance.
    Do not waste your time with all types of mental tools used by the contemporary radiesthesists.
    This is a “Twilight Zone”... ”
    From book - /The Roman Rod/ Secrets of Physical Radiesthesia
    THE ROMAN ROD - SECRETS OF PHYSICAL RADIESTHESIA
    In this book is revealed the secret of the Roman Rod (Roman Cane).
    Here you can find the laws of the antique Physical Radiesthesia, the construction of the device (original and modified) and the methodology for the exploration.
    It has been cleared that the contemporary radiesthesia is mental and mixed, but not physical. It is not based on the gravity interaction and is distant from the principles and the achievements of the antique Physical Radiesthesia.
    Here, for the first time is presented information about the Gravitational location and the Gravitational resonance.
    It is problably first time, that someone is asking for "Gravitational location" instead for Gold location and is interesting in "Gravitational resonance" instead of Gold resonance. Be careful, it is known that reaching Gravitational location can destroy your dream world.
      Radiesthesia (in other words - dowsing) is not discussed in the Geotech forums. Please make your posts at www.longrangelocators.com.
      If you are advertising (as I suspect) then do not post this in the main forums, but put it in the Buy-Sell-Trade section.
      This thread has now been closed.
