Push-pull oscillator
  • Push-pull oscillator
    Push-pull oscillator.Works well in practice with the values ​​of the capacitors of the pattern.
    That schematic will win an "Obfuscated Circuit" award!
      Thanks for the Award!
        You should be warded instead awarded.
        If you are not able to represent your design simple, simply you do not understand it.
        (proverb of Bulgarian designers)
        Ако не можеш да представиш твоя проект просто, ти просто не го разбираш.
          To mikebg
          Oscillatory scheme work. Your problem is you moron .
          ONLY FOR MIKEBG
          |Тази схема е правена и работи перфектно.Това,че не разбираш елементарни неща е твой проблем,уважаеми велики Теоретико.Кога ще видя нещо ,сътворено от Ваше Височество?Или само ще се правиш на велик с клавиатурата на компютъра?
          И да знаеш,Google Преводач често превежда погрешно.|
            More simple presentation of this can be only FOR idiot
              scs, I'm sorry, but your schematic is simply incomprehensible. Anyone interested in it will have to redraw it just to figure out what the heck it does.
                I apologize, I will send a clear schema.
                  has not deep sense. leave out.
                    Clear scheme
                      Change R5 -680om. For stable start.Click image for larger version
                        Thanks scs.
                        Can you explain what is purpose of this push pull oscillator in your metal detector project?
                          There is a large amplitude-50-70v pp .low current consummation-25ma in 10v. Detector working with small gain and is sustainable. With this oscillator I've done detector in 7.2Khz frequency.Work very deep.
                            Thank you. What changes in oscillations do you sense at target detecting? Changes in amplitude?
                              Detector is induction balance VLF tipe.This oscillator is search oscillator.Work with very stable amplitude and frequency.
