Very nice. Did you try to compare concentric and DD response? (VDI stability, object orientation, range etc). I have built only DD but want to try concentric design. Unfortunately whole thing is not finished yet, not boxed, everything is still on working table.
Yes I have compared. All the same (VDI stability, object orientation, range etc). works well.... This is a IDX Pro coil...I tried...
In modern dwellings many industrial noise.
Therefore, the device should be tested in the field or the woods away from the noise. )
But at home, too, you can check your device to turn off this coil
set thresholds S22 or S33. In this "false" signals there are no or very rarely.
I turn off the coil, the first minute there are 3-4 false signal but after total silent or very very rarely....
Anybody knows what is the optimum voltage Rx measured on coil`s ends ? I just know it must be below 1V at output AD8091, soe maximum input should be below 10mV but more precize?
