'KROT2-XM' (mole), new project Xmega32
  • This happen with last HEX only or with some older HEX too?
    • This happens with every hex Ive tried 8, 9, 10 and 11. ferrite balance works, all features work, detector functions well except random beeping. I remember while building the eduardo VDI board, the amp would overload and the detector would randomly beep until I decreased a resistor. but on this one the gain is adjustable through firmware.Beeping stops when I disconnect coil. I am using two separately shielded pairs for coil, both connected only at RX ground. I wonder if anyone else who has built this single sided Dip board has solved this problem. Any ideas?
      • Random beeping may be e.g.
        1. If you are at home, where a large amount of noise.
        2. Poor ekrannirovany PX chain. Even need to shield connector.
        3. have been set for a little over a large gain, or small rapids.
        There may be other reasons .. All this can be verified by turning off the coil Random beeping should abyss at the threshold of S44!
        • Originally posted by ANDREW K2 View Post
          Mean: Poor shielded RX front end (connector inclusive and RX line till PCB - use shielded RX wire between board and connector too).
          • Most likely, the reason screening, connection, or cable. What cable do you use?
            • http://youtu.be/wx6Ja-enAxw
              • Why thresholds 36 you are going to dig iron?
                The "0" is not necessary so often reap ...
                • If the "noise" in the printed circuit board DIP, the author recommends that these changes ... I recommend r18 is replaced by 30-100 mH choke, Dr1 not put more than 30 mH or jumper. C28 = 10uF (in the list 1 uF) and if it is a capacitor film, still put in parallel ceramic 0.1 uF! More ... Connector coil connected to the cable shield and soldered to the "cold end" PX.
                  • Originally posted by smity View Post
                    ... Dr1 not put more than 30 mH or jumper.
                    You mean 30uH? MicroHenri not MiliHenri?
                    30mH cannot be comparable to jumper inductance.
                    • MicroHenri
                      • DR1 =L1?
                          DR1 =L1?
                          Yes, Choke 1. Choke = drosselj (дроссель - Russian ) = Drossel (German) = abbr.: DR
                          • Thanks WM6, I think others are having this chattering problem with the Krot2 DIP. I hope the beeping will stop after I make the changes.
                            • Hi Wiltran, can you take some video of those chattering including clear wisible display during chattering. Maybe Andrew can then help you more.
                              • Chattering
                                I replaced R18 with 92 uh choke, Dr1 is 10 uh choke, C28 replaced with 10 MFD electrolytic. cable shield connected to RX ground. After suggested changes made, no change- still chattering/ beeping! Detector functions well otherwise, good visual discrimination, and depth. Disconnect coil and beeping stops. I couldnt find a 300 pf for C19 so I used a 330 pf. maybe change R12 from 100K to ?
                                I wound a new DD coil, 1.063 mh TX, 8.5 KHZ C1 .3 mfd., 23.5 mh RX 7 khz C0 .022 mfd.
