'KROT2-XM' (mole), new project Xmega32
  • No he said in this video, he changed the circuit and simpled it
    he dont found mc34119 In his country
    • Hi Dean,
      I buy it on "KUPUJEM-PRODAJEM" for just 350rsd, You can find it under the ARDUINO parts,
      regard Cvele
      • I finally started building this md but have brought a ATxmega32a4u-au ,has anyone used this mcu if so which version of the firmware did they use ? sorry if this is a dumb question but need to know if this will work or should I buy a Atxmega32a4-au instead ? regards Jamie.
        • Will work !!!
          I also use ATXMEGA32A4U.
          firmware work with all ATXMEGA32A4 - ATXMEGA32A4U!!!
          regards ujosvec
          • Many thanks ujosvec that is good news .could you confirm that C8 and C20 are 2200 pf and C4 100 pf ? .
            regards Jamie
            • yes
              C8 and C20 are 2200 pf (2,2nF) - C4 100 pf
              regards ujosvec
              • Thank you
                • I have a question.
                  Is it advisable to protect the pcb with alcohol and resin of colophony?
                  Is it bad?
                  • No!!!
                    absolutely clean !!!
                    ujosvec
                    • Originally posted by ujosvec View Post
                      No!!!
                      ujosvec
                      understood thanks
                      • Hi every one,
                        I made Krot-m years ago and it works quite well INDORE but on real soil -NIGHTMARE ! But with krot2-xm opposite! In My backyard it is unstable, poor depth and with 25cm(10") coil - only 25cm in the air on 25mm coin. Yesterday I try it outdoor and was pleasantly surprised. Without EM noise from surrounding, it works perfectly! Only what I have to change is diameter of coil, from 10" to 12" and it will work as it is declare. OK I know, there are a lot of DIY schematics of MD that can reach 30cm in soil but how much with so many potentiality like krot2?
                        Regard
                        • Originally posted by smity View Post
                          The new firmware. Selectable buildup TX, sinus or meander (Meander allows you to get more current for the same settings, respectively big depth of detection) mode "Power" button, "0", "the Sin", "Meander" Other minor improvements .
                          Can any native speaker tell me what "Meander" means? Is it a square wave in Russian?
                          • Meander (by the name of a geometrical ornament in the form of a broken line) is a periodic signal of a rectangular shape, widely used in radio engineering and electronics. The pulse duration and the duration of the pause between pulses in one period of such a signal are equal. In other words, the meander is a periodic rectangular signal with a duty ratio of 2 or, which is the same, with a duty factor of 0.5.
                            • Originally posted by AlexCh View Post
                              Thank you, in German the term is mostly used for rivers formed like a snake.
                              • Last weekend I was outside in the field, after searching the good things for a while and the unit was running quit and stable, my detector switched to the volume menu and stays in this position.
                                So I decides to change the firmware, but with the same result. Also with and without coil, I get only the volume in the menu and nothing can be changed.
                                Any help and suggestions are welcome.
                                Please look at this video here:
                                https://youtu.be/qYu2WDxGmhg
