Deep PI metal detector
    Hi Khaled,
    first of all, there is NO "deepest PI detector on the market", because it almost all depends on the coil size you use. Basically, you can turn any PI detector project from the Geotech forum into the "deepest PI on the market" by simply using a large frame coil and modifying the circuit to match the coil specifications.​
      I think very deep PI is possible with a special design.
      This issue can only be achieved with a different coil design.
      It doesn't matter whether the coil is big or small.
      People are walking around with 1x1m very inefficient coils. It's a completely futile effort.
      Still, an object 10cm from 5m is impossible.​
        Hi Khaled,
        The limitations are the maximum Flyback voltage, maximum power consumption, maximum delay to first sample.
        A square current wave TX design allows for more turns of wire, shorter delay and lower power consumption.
          Hi
          many thanks for your great assistance & useful feedback
          my request of maximum deep detection value is around 6 meters for hot rocks & high minerals soil ( volcanic ground )
          kindly ,can anybody specify a detector name in the market or handmade design for this purpose
          Thanks in advance
            5m
            Глубинный металлоискатель МГ-1,
ID:	420793​similar Click image for larger version
              this?
Name:	Metal detector 1921(2).jpg
                Here is a deep seeker from 1921!!!
                  deep hunter finder on 6 meters depth from modern. Magni.
                  Click image for larger version  Name:	koudekerke1.jpg Views:	0 Size:	155.1 KB ID:	420848
                    The basic rule of thumb is that one ton (1000 Kg) of steel or iron will give us a 1nT anomaly at 100 ft. or 30m. Since the amount of distortion falls off as the cube with distance (compare a metal detector which falls off as the inverse 6th power!) and is linear with mass, every time we cut the distance in half, we can see 1/8th the mass. Therefore, we can sense 250 lbs. (100kg) at 50 feet (15m), or 30lbs (15kg) at 25 feet (8m), or 4lbs (2kg) at 12 feet (4m).
                    https://www.geometrics.com/support/h...ometer-see/​
                      The difference is that the magnetometer makes a passive measurement, and the metal detector makes an active measurement.
                        and what you see on post #23?
                          Could it be fluxgate magnetometers?
                            Dear All
                            Many thanks for your kind assistance and help
                            i already have two metal detectors : GP 4500 and felezjoo pi
                            how about use them with 2 meter X 2 meter cable coil in order to reach the required depth ( 5 meters ) , target sizes (( length &width more than 60cm, hight more than 40 cm ).​
                            which one will be useful .
                            by the way these are my options :
                            P 4500 & the Iranian felezjoo pi had their own 2 meter X 2 meter cable coil from there manufacturer
                            a second option is to purchase one of the attached devices ( VEGA and REX LAND CRAFT ) with their own 2 meter X 2 meter cable coil.
                            also , i had found another Bulgarian devices named : Detech ssp 5100 , Golden Mask Deep Hunter Pro 3 which have their own 2 meter X 2 meter cable coil
                            please , advise for the correct device so i can proceed for purchasing it.
                            With all the best for this forum members
                            Waiting for yours kind replies
                              hi
                              i forget to mention the magnetometers detectors , can they do the job for above mentioned deep detection
                              Best Regards
                                The odds are well and truly against you.
                                Firstly, as kt315 [jokingly] says, your goal is definitely in LRL territory. Or, to put it another way ... it's just a dream.
                                Not only that, as a beginner in electronics, and with no experience of using microcontrollers, you're setting yourself an impossible task.
                                I would strongly suggest that you get yourself a copy of ITMD and read it thoroughly before proceeding ->
                                Inside the METAL DETECTOR - Published September 2012
