3.7V Battery Charger Schematic
  • 3.7V Battery Charger Schematic
    i need help who have schematic or pcb lay for this charger
    etch one is 3.7V 5000mAh
    i want use combine it to 4pcs battery so i get 14.8V can use it to IDX Or TGS
    This is fully functional
    Battery_charger.pdfBattery_charger.pdf
      [ATTACH]30333[/ATTACH][ATTACH=CONFIG]30333[/ATTACH]
      bro dont you have the LAY file
        I have the file format. brd eagle 6.5.0
          Hi paku,
          Just buy an rc model charger, popular imax b6ac (or any clone) will be more then enough. First of all DO check the real capacity of your li-ion cells - they are probably plain chinese sh.t, because even the best 18650 li-ions never have more then 3500mah. Most of ebay cheap 'ultrafire' junk is ~600mah, but you can find even 6000mah on the label! here you can see a good example: http://budgetlightforum.com/node/27603
            Originally posted by ppodg View Post
            Hi paku,
            hahah very nice info bro now i will try opeen in side my battery and check what i have in side
              This topic is also worth a look: http://budgetlightforum.com/node/13539
                Now I Have open My Battery I get some liquit and look like roll off plastic inside
                is that orignal or fake i get much splash when open hahaha
                  my charger works for over 5 years and has never had any problems and even the battery 18650 4200mA.
                    do you have PCB lay for that schematic cos i dont have skill to make That PCB lay
                      Well, less then 1000mah, I think...
                      traverso40, have you measured the REAL capacity?
                        @ ppodg Yes real capacity is 3800 mA after 50 charge cycles.
                        @ paku No sorry i have file *.brd from cadsoft eagle.
                          ok No Problem
                          is that on my image is original UltraFire Battery Or Fake Battery
                            @paku: fake, of course, well below 1000mah, I presume.
                            @traverso40: manufacturer, please? As far as I know the largest 18650s are 3350mah by Panasonic
                              Ultrafire , nominal 5000mA effective 4200-3800
