Deleted
Aquasound
Here schematic (rev 1) related to the available photos from KT315:Attached Files
sorry, output transformer. it transforms a voltage in a current. then primary would be more, secondary less.
Coil must be set at 0 degrees phase, very important when making the coil.
(According to the patent) "the coils are adjusted for 0 degrees phase shift of an impressed test signal from the tx coil, as received by the RX coil."
That's fancy language for saying that the coils are balanced by phase and not by minimum residual voltage.
However there is one caveat. No mention is made of whether the RX is tuned or left untuned while balancing for 0 degrees phase shift.
I ask this question because I know phase shift is frequency dependent, is it not?
So is it 0 degrees tuned or 0 degrees untuned?
Given the fact that this detector has feedback adjustment pots for both voltage and phase, I think the 0 degrees phase shift is with the tuning capacitor. But I'm not certain.
my mistake. this transformer is for piezo element, not for a speaker connection . so secondary part has more winding, because piezo 'needs high voltage'.
first issue is RIGHT.
http://kamrad-club.ru/-razdel-master....html#comments
