Originally posted by moodz
What is this circuit component?
Originally posted by Arthur-Canada View PostAnyone know what is this component labeled 8838?
[ATTACH]36975[/ATTACH]
--- 63V
There's some other Wilson ccts on here, the 710 has a 220.0 crystal exactly like yours: Zip file:
http://www.geotech1.com/forums/attac...5&d=1212523464
Parts list: txt
http://www.geotech1.com/forums/attac...9&d=1212613891
Taken from this thread:
http://www.geotech1.com/forums/showt...ETECTOR-S-quot
Also: Coin Select pcb:
http://www.geotech1.com/forums/attac...9&d=1351758761
Regarding testing the part, you could probe around the nearby IC with a 'scope looking for 200 KHz / 100KHz etc divided down digital signals.
Or you could remove it from the PCB and make up a simple logic gate inverter based crystal oscillator, eg. 4000-series logic (CD4020 for example).
Just for technical interest: The operating frequency of this machine (and several other similar Wilson-Neuman machines) is stated as 6.875 KHz. This is 220 KHz divided down by 32.
I also noticed their publicity states "Binary CMOS search-coil", which I guess is advertising baloney hinting at the digital 4000-series logic that drives the coil frequency.
The audio tone is also quoted as 215 Hz, which is 6.875 KHz divided down by 32. My guess is the 'unmarked' chip is a CD4020 oscillator/divider.
At that frequency, the only main choices are ceramic resonators and tuning-fork crystals. I've used 100 kHz conventional crystals before, and they were huge (HC6U maybe ?) and expensive, not really suitable for detectors. It's probably lack of choice that led to that part.
The other obvious alternative is to use a higher freq crystal( >2MHz ) with more division.
I've just remembered another place I've seen that ceramic package. You used to be able to get a programmable oscillator/divider IC, in a regular DIL package, but with this ceramic boxed crystal visible in the top of it. You used pin selection to get the output frequency you wanted. There were two or three different master crystal freqs available. I can't find any mention of them on the web, and I've no idea if I have any 'spare' parts from the project I used them in, approx 1992.
Edit: Found it: Statek PXO series.
http://www.ebay.co.uk/itm/1PC-STATEK...-/121492945994
http://www.silicon-ark.co.uk/surplus...ator-by-statek
http://www.datasheet4u.com/datasheet....php?id=539290
Notice the date codes of these parts, 1984, 1987.
Yes,I see. Why has no one used these in designing Tx oscillator to drive Tx coil and for phase shift. I've never seen these before in any metal detector schematic. By the way, I want to build the GC 1023 and have discovered that it is an exact clone of the fisher f2. Now all I need is a schematic since there good pics of the PCB on this forum.
