Deepers Detector
  • Deepers is good detector. This one can determine by reference to schematic. Good design, single sample, elegant yet simple. Use correct op amps and you will have a winner.
    No way worth $2400. This is crazy price.
    • Pleas can you put a file complet of deeper x8 that works well
      • ok mfc give me your mail address i'm messing around deepers 10 dd made some mistakes do you help me greetings
        • tamam mfc bana mail adresinizi ver ben derinlemesine dolaşıyorum 10 dd bazı hatalar yaptım bana selamlar yardım et
          • (you can fix a small detail or diode back in the resistor)
            what are the resistances and the diodes
            • Hi soylu all deepers are good projects for make. In my opinion all are the same with very small changes see the schemes carefully for comparison and you will see. I had used Deepers 7, 8 , 2x1 and X5. The main reason for the Deep of detection in X5 in general is the Frequency range from 550 to 950 Hz, take in account that a higher frequency is better for detect metal but in a reasonable range. Too hight frequency is bad choice when the soil is mineralized.I am working in the schemes constantly for corrections and give all you a 100 % funcional Deepers Diagram for build. Give me a lot of time.The Deepers 8AT posted in the forun is OK. I had make it and now I am using it, believe me is very good and have excellent Dept.
              • if this address is correct I send 10dd lay file
                • maikelfcmfc@hotmail.com
                  • I sent you to your address
                    • Can someone publish Deepers 10 DD files lay. or pcb. ?
                      • only on a schematic stage.
                        • Thats very interesting KT315 do you have a rough time frame for PCB production ?
                          • KT315,
                            Can you upload the schematic as pdf?
                            • guys it is still not finished. i do if i have get a time. i have to check all and then will load it.
                              • To all friends . I want file of deeper x8 that works good .Help deeper x8
