pulse star ii schematic
  • pulse star ii schematic
    THANK YOU FOR ALL PEOPLE THAT SHARE INFORMATION ABOUT METAL DETECTORS AND VERY THANKS FOR DESIGNERS AND PROFFESIONS. dear all friends:i want build-in puls star ii pro;please if anyone have schematic and pcb .lay file please post.and so if anyone have sd2000 pcb lay file and schematic share it.i want know WHICH OF THIS DETECTORS (PI DETECTORS)GS4-PULSE STARII,SD2000,DELTA PULSE ,DEEPER10,DEEPER8,HAMMERHEAD; IS BETTER FOR BUILDING AND WHICH IS DEEPER DETECTOR?WHICH RECOMMENDED FOR BUILDING OR ALL ARE SAME.
    good luck.
    Hi friend I recommend you a Deepers Detector, is a Good project and it work, you must wait a Lot, for completing the sch of Deepers 10DD or you can build the Deepers 8At, it work fine but you need a little knowledge of electronics because for a beginner is a lot complicate.
      Pulse Star II is a microcontroler IC and you need the software, to much difficult, I recommend you may be the Pulse Star BG or G.
        THANK YOU VERY MUCH
          Where can I find the Pulse Star BG and G scheme?
            this forum has advanced SEARCH engine. please less ask and more search.
            pleasure
