Clone PI-W komplete
  • Clone PI-W komplete
    30 cm coin 25mm
    схема
    Замена ADG444 на CD4066:
    плата:
    3 hex full versions:
    CPI_W_1.22m.rar
    CPI_W_1.24.rar
    CPI_W_1.25.rar
    Coil:
    Inductance winding – 317uH.
    Interturn capacity – 80 pF.
    Resistance coil - 1 Ohm.
    Range detection of coins of the USSR 5коп – 31cm.
    https://translate.yandex.ru/translate
    http://www.metdet.ru/Sensor_K1.htm
    Clone PI-W needs no adjustment (if is necessary only twist one trimming resistor)
    Fast basket coil (low cap) does not require adjustment.
    Grounding in star point. One connection to Bat-.
    Technical specifications Clone PI-W public:
    -Principle of operation of pulse induction
    -operating frequency 200 Hz
    -Mode static & dynamic (in latest firmware)
    -the Depth of detection by air - sense gold ring 25cm
    -coins 25 mm – 30cm
    -small gold objects - 5cm
    -gold coin - 15cm
    -helmet - 80cm
    -maximum depth 120cm
    -Power 8.5-12V
    -Current consumption 100-160mA
    Parts list
    IC:
    Atmega8-16PU (8A-16)
    CD4066 or К561КТ3 (instead of ADG 444 )
    TL074 or TL084 or TLC274
    Transistors:
    MOSFET IRF740 or КП776А or IRF630 or IRF840
    Bipolar 2S9014 2N5551 or КТ503 or КТ3102 – 4 PCs
    FET:
    КП501А or BSN304A or 2N7000 (or CT 315 cut the track to the base and connect the base through a resistance 7-10K)
    Voltage reg. 78L05
    Volatage ref. TL431
    Diode:
    1N4148 or KD522---2pcs
    Capacitors:
    470pF - 4pcs
    1.5 nF
    10nF – 2pcs
    47nF
    100nF - 2pcs
    4700,0uF x 16V
    1000,0uF x 16V
    220,0uF x 16V
    470,0uF x 10V
    Resistors:
    20 - 2pcs
    47
    100
    390 - 2pcs (preferably 1W - 2W)
    510
    1K - 3pcs
    1K peremenik (500 Ohm multi-turn )
    3K - 2pcs
    5K1
    10K - 15pcs
    12K - 2pcs
    47K
    100K
    2M
    Clone PI-W original
    ClonePI-W.pdf
    НА ХАЛЯВУ И УКСУС СЛАДКИЙ - FOR FREE WINE VINEGAR IS ALSO SWEET.
    CLONE PI-W SPRINT
    Clone PI-W.ZIP
      CLONE PI-W SMD
      Clone PI-W SMD.zip
        What is the thickness of the wire this spool?
            pustareka just is repeating that i had given much years ago. i wait now he begins to tell us about QUASAR ARM and how thats good.
            nothing new under the sky on this planet... same info many years running.
              ничего нового кт315 ???
              https://www.globalresearch.ca/china-...form=hootsuite
                принеси нам Квазар АРМ. удиви!
                  http://www.geotech1.com/forums/showt...NE-PI-released
                  2005 year i did this post. new? 13 years had gone, amigo.
                    Вот он Квазар ("Quasar") Металлоскатель на контроллерах AVR и STM32.
                    http://md4u.ru/viewtopic.php?f=95&t=8594&start=0
                    http://fandy.ucoz.org
                      Whats up?
                        Please stop making non-English posts.
                        Write your posts in English -> Basic Rules of the Forums otherwise I will start deleting them.
                          horosho -ok. https://translate.yandex.ru
                            CLONE PI-W 30 cm coin 25mm
                            not bed 30cm.
                              30cm "depends on the soil" but great simple pi detector, dont use it around housing area, or u will be a nail collector
