Tesoro Compadre Schematic PCB Rev 4.1.1
  • #31
    do your home work hard http://ipic.su/img/img7/fs/P3173294.1542657539.jpg
    • #32
      Capacitors were removed one at a time. They were measured and replaced immediately. I will remove and test again.
      • #33
        I removed and tested C2 and C24 again. Apparently I made a mistake when I entered the data to the schematic. I had not swapped them on the PCB as they were removed one at a time. I entered the wrong data on the schematic. It is corrected now and I have redrawn the schematic to make it more pleasing to the eye in certain areas.
        Revison 5
        Merc
        • #34
          Hi friends kt315 please i dont know about king kobra coil rx and tx .help if you have enny idea.
          people ask me to give data on coil of King Cobra. i tell again its same like Compadre coil. i think Merk will give us info.
          • #35
            Which one would you like info? King Cobra or Compadre?
            • #36
              compadre. thank you
              • #37
                The Compadre can be ordered with either the white 5.75" concentric or the brown 8" concentric. The one I have has the brown 8" concentric. Specs are listed in the forum. It is the same as other 5-pin Tesoro coils. I don't know the number of turns of wire and such. I have posted a question in the Coil area of the forum because I'm not sure that the white and brown Tesoro 5-pin coils are the same specifications.
                Merc
                • #38
                  guys
                  i ask you again to learn to use a light. simply try do perfect pics. no something secret from me, i am also just beginner.
                  http://www.geotech1.com/forums/showt...here-share-out
                  you must not be pained on me. i want just to lift up this forum on new level.
                  • #39
                    my collection of files. find a folder COMPADRE. open. find up a folder HR PICS. you see HR pics of the board. http://depositfiles.com/files/s6obi13mk
                    please be good enough to send me YOUR pics in HR (HR is 5-10MB size pic. not 290kb. not 360kb. not 1mb. FEEL THAT AND GRASP THAT).
                    again thanks to sender of those pics to me
                    • #40
                      this is Flo guys. very much of american light around you! palms and kaktuses! kaktuses and palms! much negros and amigos too around!
                      real SUN COUNTY THERE! your dream to be there eahh???
                      • #41
                        Kt , Did you photograph this image ?
                        • #42
                          • #43
                            look at this. where you see cactuses and palms amigo? you see just white, grey and black color in all! cold, snow and NO SUN! no negros, no amigos, just
                            grey everywhere!
                            • #44
                              This looks like a good time of year to be inside building metal detectors. It is cold and rainy here now. I will take PCB pictures for you when the sun returns.
                              Merc
                              • #45
