PinPointer or Hand Held metal detector Schematics Help
  • PinPointer or Hand Held metal detector Schematics Help
    Hello,
    I need a PinPointer schematics that to find metals up to 50cm. If anyone know any PinPointer or hand held metal detector that works I will be thankful if send schematics or suggests me what schematics if suitable.
    Great! Finally we are asking for long range pinpointer too.
    Do you consider 50cm as sufficient?
      Hello,
      You need an x-rayPointer.
        Hello wm6,
        Because I am not searching for small nuggets or a coin. So I asked for help to find low distance metal detector, not 2 or more meters, only up to 50cm for big objects.
          What does it mean?
            Why a pinpointer for large metal objects at a distance of 50cm? This is like standing in front of a bus and hoping to get hit by the fly on the bumper. Makes no sense to me.
            You could construct a mini Radar system, but then you would require a tin foil hat for protection from the radiation. And the Authorities would likely place you into permanent quarantine.
            Seriously though, I don't know of any pinpointer that meets your criteria.
              I did however find this pinpointer on YouTube.https://m.youtube.com/watch?v=2WFCzP_8LSY
              Perhaps something like this can detect large objects at a distance of 50cm.
              It's not exactly your traditional "pinpointer", but it is small enough to be a practical solution. You could package up a Pickini 4 in such a housing and you would be good to go.
                Thanks.
                This is what I need. I need short range metal detector.
                Is there any projects or schematics that I could build and works?
                  You can have a look at PICKINI V4 project.
                    It is successful project. I will try to build one of Pickini.
                      Only 50 cm? How about one that finds the gold for you while you sit at home in your comfy chair? (I'm working on it, not much progress yet, but I'll get there).
