Pinpointer with discrimination "Cat-FM" on ATMega328P
  • Originally posted by useus View Post
    the three degrees of sensitivity can be improved, at the moment the targets are too close depending on the sensitivity level.
    it would be good for example: 1 euro coin
    -level 1 1,5cm
    -level 2 3 cm
    -level 3 maximum detection
    Ok, within few days I will public new 1.5.3 version.
    • Hello friends I just finished my PCB Lay.
      Can you check if everything is okay?
      • Originally posted by Ruben2000 View Post
        Hi Ruben, I can advise you to use "EasyEDA" environment, once you created schematic there you will never do mistakes In your PCB design.
        • Originally posted by void118 View Post
          ok void118.
          I'm going to download it and start using it.
          Thank you very much for your advice.
          • Could you give me some points that I should take into account when designing my PCB?
              Hi, place generator parts as near as possible each other, coil capacitor(33nF) must be as near as possible to coil connector.
              Buzzer, LED and Vibro place as far as possible from generator. In general, that Is all my friend. And take a look on Useus design, there Is generaly correct layout.
                I am also working on perfecting it because I tried it outdoors and there is a lot of instability, it sounds progressive from slow to fast with no target. sometimes it also goes haywire, I have to turn it off, wait 1 minute and turn it back on. I think it is a question of pcb,
                of capacitors or the bc547 and bc557 transistors are not good at worst
                  Hi, first try to use 1.5.1 firmware with "1" sensitive and tell me about your coil please.
                  Second , you can try to wrap the sensor into aluminum foil and ground It, It's looks like earth magnetic field Impact. Where are you from friend?
                    Thank you very much my friend void118 !!!
                      firmware 1.51 all levels of sensitivity does not change anything.
                      now i temporarily shielded the coil as you told me and it's almost perfect thanks, i didn't understand what it could be. strange because during the tests he didn't do it to me.
                      I have two coils that give me the same effect, a 2.2mh 0.26mm wire 4 layers 25mm coil and a 2.4mh 0.45mm wire 2 layers 45mm coil. both on 2x 100x10 ferrite
                        It's protection(shield) against earth electromagnetic field.
                          yes that I know, thanks. I meant that I did not understand what the problem may have been, thanks again for helping me !!
                            The problem was In shake of earth's magnetic field, It can cause generator frequency shift I suppose.
                            Ouh, I understand, actually when you tested It on the table the coil was fixed relative to the magnetic field, but when you moving coil you can see sthe same situation like In compass, you moving compass and arrow moves too. This Is very similar situation I think. Nearest feature I will try do reduce generator frequency to 10kHz to reduce this effect.
                              great, then before shielding the coil definitely I await your upgrade!
                                Ok, now I'm looking for people who will support my project because development requiers certain costs and until this moment I will probably suspend my work on the project.
