Pinpointer with discrimination "Cat-FM" on ATMega328P
Originally posted by zakari View Posthi
how this circuit discriminate?with voice of buzzer?because in the schematic there are the leds but there isnt any led in the pcb
void 118 can you explain ?in the schematic atmega has 32 pin but in the pcb has 28 pin?
best regard
zakari
Friends,
I've made new video but I have no Idea when youtube will add subtitles to It.
https://youtu.be/phZfdfi7Wio
Thank you Void118 and Useus. Does anyone know where I can find a diagram to make a new Atmega328P target pcb please? I programmed my first Atmega328P with the V1. Hex and it programmed OK. But when I came to use my target pcb to re-program it for the new External button Hex it couldn't recognise the Target IC. I may have to build another target pcb for my USBasp or is there another method I can use to program the chip? Thanks again guys, regards, Marty.
Originally posted by MartyJ1963 View PostThank you Void118 and Useus. Does anyone know where I can find a diagram to make a new Atmega328P target pcb please? I programmed my first Atmega328P with the V1. Hex and it programmed OK. But when I came to use my target pcb to re-program it for the new External button Hex it couldn't recognise the Target IC. I may have to build another target pcb for my USBasp or is there another method I can use to program the chip? Thanks again guys, regards, Marty.
Or may be you confused low and high bytes?
See In attachment fuse bits for AVRDude, and download nice utility I sad before.
"eXtreme Burner"
https://drive.google.com/file/d/1ZYfU81vVVEhajylHBZ_r0KQclQl-xTvK/view?usp=sharing
fuse bits for AVRDude:
https://drive.google.com/file/d/17WFF9bvedS9Mx81n2RCXChocCOlb6bSm/view?usp=sharing
Originally posted by MartyJ1963 View Post@Void118. Great work on the latest video! and many thanks for all the necessary information you included. It was very kind of you to offer this interesting project. The subtitles have not been added to your youtube video yet so I will download it again later. Thanks again, Marty.
