Pinpointer with discrimination "Cat-FM" on ATMega328P
  • Originally posted by useus View Post
    i don't understand how you connected it, gnd ok, i/o ok, while vcc and the soldered wire?
    It's not soldered wire It's thermocouple to show you transistor temperature....
    • Originally posted by void118 View Post
      Emitter to VCC, Collector trough buzzer to GND, In parallel to buzzer 1K resistor, sound to base through 1K resistor
          [ATTACH]55230[/ATTACH]
          Or try to use electromagnetic one like this
          https://www.amazon.com/Universal-Pas.../dp/B08FR7LBHK
          • Just now I tried to connect electromagnetic 16 Ohm buzzer and It's much louder than piezo buzzer....
              Hi, don't touch It please)
              Ok I will try again, what is the hex value for the LOCK FUSE ? thanks
                ok then it's as I thought. I already own it electromagnetic but it is 45 ohm so the noise is lower. the strange thing is that with a normal passive piezo it doesn't sound at all
                i will buy a 16 ohm one
                i wanted to be sure before printing the pcb
                • Hiya guys,,,@Void118 - Thanks for the new code, it works great. I have made the 1/2 Ferrite coil - 50mmx10mm. The Inductance was 2.945MH and I used a 33NF Box capacitor. It detects a UK 10p at 1.5 inches,,,a UK 20p at 1 and 3/8 of an inch. I wll test later with other targets. Since I loaded the V1.3 Hex file the volume of the piezo has increased. I can hear it enough now to use in the field although I have placed an order for the same passive buzzer piezos that Void118 kindly gave a link to. I'm really pleased with this project Void118 has gifted to us and it is the best pinpointer that I have made, personally, to date. It would be even better if we could add a vibro-motor for extra target indication.Thanks again Void118 for this brilliant little project. Regards, Marty.
                    0xFF
                      Thank you Marty), try to use this electromagnetic buzzer It will sounds much louder
                        Hmm, It's realy strange....
                        • @6666,,,,,,,,,,,I've sent you an email regarding the ATmega programming steps I used wth AVRDUDESS 2.13. Regards, Marty
                          • @Void118 - Thanks for the new link. I already ordered the others now but I will order some of these too. I plan to make a few more pinpointers! Regards, Marty
                              Thanks Marty
                              • Friends, just for sensitivity testing, here Is test version of firmware with high sense:
                                Cat_FM_v1.3_high_sensitive_experimental
                                https://drive.google.com/file/d/1KM1...ew?usp=sharing
