Pinpointer with discrimination "Cat-FM" on ATMega328P
  • The pcb walkman works fine i make it it staible and good deept .
    • @Void118,,,Thanks for the help,,,I will try to decrease the capacitor. @Walkman,,I made your pcb and placed everything correctly but I still cannot get it to work. Do I remove the 100nf capacitor? And is there anything else I need to do? Thanks, Marty.
        Hi friend sorry to late for answer.
        cat_fm_v1 for only 100nf removed.
        • Rebuilt Cat_FM_V1 for pcb.Tested and work.
          • Thank you Walkman,,,Can I use BC327 instead of BC557, and BC337 instead of BC547? Regards, Marty.
              Hi Marty1963,
              BC557 instead BC157, BC558, 2N3906, 2SA1943, BD140, S8550, TIP127, TIP42
              BC547 instead BC549, BC636, BC639,
              2N2222, 2N2369, 2N3055, 2N3904, 2SC5200
              • @Walkman, I'm very grateful for the help. Thank you for the alternative list you posted. I will add it to my reference folder for the future. Regards, Marty.
                • Originally posted by void118 View Post
                  [ATTACH]55450[/ATTACH]
                  It Is mistake, 2.2uF plus must be connected to emmiter, so this Is right connection
                  sorry my mistake
                  • Friends,
                    If you want I can arrange youtube stream to answer all your questions related to Cat-FM schematic, what do you think?
                    • Originally posted by walkman View Post
                      Hi Marty1963,
                      What a stupid advice (((Use transistors in TO-220, TO-126 instead of TO-92 ... Transistors are boldly replaced by BC327 and BC337...
                      Moreover, they have better parameters.
                      • Friend i tell you iam making walkman pcb without removed capacetor 100nf . I tell you it working fine and stable i test it in ground
                        • Hello fiends,
                          anyone who wishing to take a part In testing the commercial version of "Cat-FM" firmware can write to the e-mail [email protected] with subject "Cat-FM"
                          All test participants will receive the commercial versions for free. You will need working "Cat-FM" board, PC with Internet access and USBASP programmer.
                          New software will be uploaded remotely.
                          Best regards
                          • @Void118 and @Walkman,,,,Thanks for the great project! I made your 1st original pcb and it works great! Thanks Walkman for your layout,,it works great too! Really pleased with both of them!
                            @Walkman,,,Would it be possible for you to make an SMD Version with Vibro motor instead of LED's please? Sorry if I'm asking too much. Thanks and regards, Marty.
                            • [email protected] void118 thanks.
                              • Originally posted by sbalio1 View Post
                                Hi, what for you send me your email friend?
